Home > Maintenance & Mods (L322) > Identify please
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
Identify please
Can anyone tell me what the body kit on this car is please?
 Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #558534 21st Jun 2020 9:45pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #558536 21st Jun 2020 9:47pm
Simon_CSK
So a body kit supplied my Land Rover at the point of sale. Does that make it an Autobiography? Current cars
Range Rover CSK
Discovery 3 HSE
Post #558540 21st Jun 2020 9:55pm
mjdronfield
It was an option when new. I’m not sure that only Autobiographies had it.
Limited the off road ability, obviously. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #558543 21st Jun 2020 10:02pm
Can get one cheap here....
https://shop.sixonetwo.co.uk/range-rover-v...-2012.html Pete
Post #558545 21st Jun 2020 10:07pm
Simon_CSK
I've got one.
Just bought that Range Rover 2007 with FSH and 72k on the clock. Not bothered with off road ability more concerned about fitting a tow bar. Current cars
Range Rover CSK
Discovery 3 HSE
Post #558546 21st Jun 2020 10:10pm
pld118
On the L322, if that’s 2012MY for example, were 2012MY AB door handles not colour coded (they’re Brunel in the OP)?
And are those wheels not RRS style?
For example, 2007MY didn’t have those front or rear lights?
To confirm original spec of the car, if you phone your local LR parts department and give them the chassis number, they should be able to email you the full original spec 👍🏻
Post #558548 21st Jun 2020 10:16pm
Simon_CSK
I have bought it because of the low milage and FSH. It is a very clean car. It has an Autobiography badge but suspect that is "dressed to impress" Current cars
Range Rover CSK
Discovery 3 HSE
Post #558550 21st Jun 2020 10:21pm
mjdronfield
Got Range Rover Sport wheels and tyres.
Looks tidy. Not sure if there is a cut out for a tow bar in the rear bumper, though I’m sure you could make one if you took your time. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #558552 21st Jun 2020 10:37pm
Simon_CSK
I have had a look at the towbar on my HSE and that drops down very low compared to the standard back bumper. My hope is that the towbar will sneak in underneath this bumper without the need to cut it. Current cars
Range Rover CSK
Discovery 3 HSE
Post #558553 21st Jun 2020 10:45pm
mjdronfield
Nice one.
There is a pic here of the bits for the rear bumper, if you do end up having to tweak it.
https://www.supertweaks.com/range-rover/ra...rs-genuine 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #558554 21st Jun 2020 10:46pm
Simon_CSK
Looks like the centre bottom section is separate so hopefully that can be removed if additional access is required. Current cars
Range Rover CSK
Discovery 3 HSE
Post #558557 21st Jun 2020 11:09pm
I've got the body kit on mine and the standard LR tow bar with removable swan neck. Its a bit of a pain of an arrangement compared to no body kit, but it works well enough. To fit/use the tow bar you need to 1/4 turn the four location pins on the undertray and pull it off - you cant have it and the tow bar fitted at the same time. Then everything is just about get at-able to use the tow bar /electrics as normal. If you want to replace the undertray once the tow bar receiver has been fitted but the swan neck removed, then you'll need to cut a slot in the undertray the width of the receiver to allow it to slide back into position. I think its all a bit fugly without the undertray in place but if you're not bothered its a lot less pfaff to leave it off. A couple of old pics.
Bodykit where you can see the slot cut in the undertray for the receiver
With the swan neck fitted. I always tape up the bumper when using the tow bar because there's very little clearance to fit the tow arm and it avoids most of the inevitable scratches.
 Mike - MPx
Post #558559 21st Jun 2020 11:29pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Hi Simon,
My 2012 MY Vogue SE 4.4T DV8 has the same external body kit, factory fitted from new.
 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #558563 22nd Jun 2020 4:34am
Simon_CSK
Mpx
Thanks for the info so really heed to think about a reeiver hitch.
Morrison
Thanks I like black cars lol have three already this makes 4. Current cars
Range Rover CSK
Discovery 3 HSE
Post #558567 22nd Jun 2020 8:04am
