Home > Technical (L322) > Rumble/vibration at higher speeds - SORTED (pg2 post 7) |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 147 |
Look at the heat shield for the rear prop/exhaust/fuel tank?
13th Jun 2020 8:10am |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 |
Wheel bearing. 2006 4.2 SC |
13th Jun 2020 8:28am |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Did the issue start after they changed the CV joint?
13th Jun 2020 9:43am |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
They actually changed the gaitor not the joint.
14th Jun 2020 8:42am |
Just to eliminate the CV joint - have you checked the gaitor is secure and properly fitted - if not, the grease will have come out and the joint may be getting damaged. I assume you had the gaitor replaced because it was split?
14th Jun 2020 8:53am |
Yep had a split gaitor
15th Jun 2020 9:05pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
Does it change if you steer left / right, if so look at wheel bearings, if it remains the same have a look at propshaft centre bearing. The centre bearing on mine started to fail, the first sign was a gentle ticking noise when slowing down, it started at around 30 mph, over the next 1000 miles it developed into a rumble from 50mph upwards and then got much, much worse. I had a new propshaft fitted by Green Oval and everything was good once again. BMW i3 Electric Car
16th Jun 2020 6:32am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
It's been spoilt for sure up there Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
16th Jun 2020 8:17am |
Got the car back - gearbox much smoother and car driving well
17th Jun 2020 10:44am |
Give them a second chance? Call and tell them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Jun 2020 11:36am |
Yep you’re absolutely right and I called them straight away. They asked me to take it back but at near enough a 2 hour round trip i won’t be soon. Will try the local person at suggested by joe90 1995 4.6 v8, green/tan (long gone)
17th Jun 2020 12:04pm |
Fair point Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Jun 2020 12:38pm |
Been back to Keith Gott who still can’t replicate it, and I can’t take the technician out due to distancing.
4th Jul 2020 6:04am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
Stupid question.....slight bulge in the tyre maybe?
4th Jul 2020 9:18am |
