Home > Maintenance & Mods (L322) > Electrical glitches?
just0007
Hi chaps advice would be great. On holiday at the moment now in Dorset but yesterday in Cornwall the car would not start. When it did start suspension fault, transmission fault, parking brake fault and although the car was running no revs showing and no power steering. Tried starting this morning and issues back switched car on and off a few times and fine for drive to Dorset now the issues are back! Big Cry Any ideas would be greatly appreciated, thanks in advance Justin
Post #56653 25th Mar 2011 2:58pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
H'mm check your drive belts.
Revs are often driven from the alternator.
Power Steering is also driven from a drive belt, can't think of an electrical reason why it would fail.
Other electrical items do shut down when voltage is low.
Does the charge light go out or flicker? 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #56661 25th Mar 2011 3:10pm
just0007
Thanks the belts look fine, hopefully it will get me back to London tomorrow and then she is booked into the dealer for some attention on Monday. Sad
Post #56668 25th Mar 2011 4:16pm
just0007
The charge light does go out, when I have the transmission fault it states that I have limited gears
Post #56669 25th Mar 2011 4:19pm
a shot in the dark justin but have you tried disconnecting the battery, seems strange that the faults dis-appear on several turns of the engine.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #56671 25th Mar 2011 4:26pm
just0007
Hi Stan I have just dis connected the battery, how long should I leave it before I power it back up? Thanks to both of you for the advice and guidance.
Post #56675 25th Mar 2011 5:12pm
half hour should get rid of any juice in the ecu's...fingers crossed. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #56676 25th Mar 2011 5:16pm
Lookers Park Royal
Wink
Post #56679 25th Mar 2011 5:43pm
just0007
Quick update, tried dis-connecting the battery problem is still there but now problem is consistent. First attempt to start and nothing the car is dead will not turn over, second attempt to start and car starts with numerous transmission faults, third time lucky car starts and no problems showing. Now back home luckily car at dealer on Monday, they have very kindly organised a new 4.4tdv8 as a loaner and to try and tempt me Cool
Post #56781 26th Mar 2011 1:06pm
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
another shot in the dark but im sure ive read it on this forum, that there is an adjuster on the gear leaver and that it dont quite see the RR in park mode to start it? thus adjusting this sorts out the starting issue.
hope it sort of helps
ian ONE LIFE LIVE IT
Post #56811 26th Mar 2011 3:20pm
just0007
Thank you for all the advice, just picked it up after a week of being without it. It turned out to be a problem with the ignition. It was not always registering that they key was in the right position. Great to have it back Mr. Green
Post #58148 1st Apr 2011 3:50pm
