Home > Technical (L322) > getting a slight droning noise UPDATE
Suggs
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Hi all 2003 4.4 V8 100k on the clock
Not sure if this has always been here and im just noticing it so now im listening out for it but when driving im randomly getting a slight droning/rumble from what seems like the tyres, its random and no pattern to it. I live in the sticks and the roads are all pretty crap even the bigger A roads and it sounds like when you go from a smooth bit of tarmac to a ruffer bit if you no what i mean. It last a few seconds then stops and nothing but will randomly do it again, I cant feel it just hear it. The car runs 100 percent normal and went through its mot 2 weeks ago with one advisory of slight wear to a rear lower arm rose bush could that be it ? didnt notice the noise before the mot. I just fitted a brand new set of tyres today and noise still seems to be there so not a bad tyre, also if i slip it in to neutral the noise will still appear if that means anything. Its one of those noises that you dont notice until you do then you keep noticing because you're looking for it lol.
Thanks
Paranoid Harry
Post #568520 1st Oct 2020 5:39pm
Range Rover L322
Change the lower rear arm rose bush and turn the music up Wink
Post #568542 1st Oct 2020 9:31pm
Suggs
I'll have to purchase some pop music Smile
Post #568548 1st Oct 2020 10:24pm
Range Rover L322
... one step beyond ?
Post #568551 1st Oct 2020 11:03pm
Suggs
haha always play that one in "our house" Smile
Post #568571 2nd Oct 2020 8:39am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I know this feeling well, I had a similar noise (thought possible wheel bearing). Changed tyres, straight through the MOT with no advisories & wheel bearings fine ?.
Sat a couple of mates in the car & they couldn't hear anything Big Cry
I've now turned up the radio a notch & wait for something to fail or fall off Thumbs Up
Post #568580 2nd Oct 2020 10:27am
Suggs
yep im going to do the same, if i take it to a garage they will just say its tyre noise from the crap roads and all terrains. I think we all notice things out of place on our own cars that others dont, pretty sure i wouldnt notice it in another car...
Post #568588 2nd Oct 2020 12:21pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I could be talking rubbish here, but I seem to recall in the early days of the L322 they were fitted with Goodyear Wrangler tyres, which caused road noise when part worn that sounded very much like wheel bearings (and, in fact, were subject to warranty claims in the US, but not here - big surprise) and one of the reasons LR changed OE tyres to Pirelli Scorpion. So, it could be tyre noise, I notice a bit of tyre noise in mine very occasionally that some might think was wheel bearings, but it definitely isn't. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #568595 2nd Oct 2020 12:54pm
Highroller
To be honest, I think this is my problem (like the old Land Rover sound), as I run Pirelli Scorpions. Thumbs Up
Post #568611 2nd Oct 2020 2:18pm
Suggs
I just changed from Scorpions to Grabber AT-3 and didnt stop the noise, does sound like its coming from the tyres though but as its not constant and only last seconds when it happens its hard to pin point it. I have read of people saying similar and it turns out to be the torque converter so fingers crossed its not that, i have found it still does it if i put it in neutral and coast for a while so not sure if that makes a difference..
Post #568616 2nd Oct 2020 2:27pm
Highroller
Mine also comes & goes, Therefore I have put it down to the tyres.
Either that or we're both in for new torque converters Shocked Rolling with laughter
Post #568619 2nd Oct 2020 2:43pm
rvbush
Just to clarify, it was the Goodyear Wranglers that were guilty in the early days. Drives:
Post #568620 2nd Oct 2020 2:45pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Suggs, has the gearbox/TC been done at any point? Thumbs Up If not, based on my experience that's what it sounds like !
Post #568635 2nd Oct 2020 5:12pm
Suggs
no its the original box, and thats what im afraid off although no other signs
Post #568644 2nd Oct 2020 6:09pm
Rosco
With my 04 petrol it was the same paranoia ! you know when something is not right and really know what it is Rolling with laughter I tried all the brake caliper/warped discs.wrong tyres but knew what it was, if you get it early may not be so bad, in the end I had gearbox and TC for c. £ 1500 Thumbs Up
Post #568648 2nd Oct 2020 6:43pm
