Home > Technical (L405) > No service menu? Can't see TPMS air pressure levels. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34940 |
are you trying with ignition on and engine off? ... - .- -.
25th Oct 2020 8:37am |
cxdood Member Since: 05 Jul 2020 Location: USA Posts: 58 |
No, that's probably it. I'll try that, thanks. |
25th Oct 2020 7:24pm |
I went to the menu with the ignition on and engine off and did get to the Service Menu. The bad news is that it does not show any air pressure values from any of the tyres. Only the recommended values are shown in parentheses.
26th Oct 2020 6:42am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Incorrect.
26th Oct 2020 7:58am |
that part number comes up on our UK ebay as working on 433mhz..
26th Oct 2020 10:22am |
stan, thanks for checking. The sensors are supposed to be 433 Mhz according to the listing for the sensors I bought.
I'll be relieved if that's the problem and it can be fixed by activating them that simply without taking off the wheels and tyresz and replacing the sensors. Do you know if that model Autel device (401) can "wake up" new OEM Land Rover TPMS sensors? I could go to a tyre shop, but depending on how much they charge, maybe the price of buying the device is worth it to activate them for this current issue and also do diagnostics in the future. I now have a summer and winter set plus a full size spare. From your profile it looks like your car is a 2014 - is that why it doesn't show live numbers in the car dashboard? Even though I should be able to see the pressure on the dashboard I can imagine that seeing the battery levels with that external TPMS tool might also give some more peace of mind? I had the LR dealer install everything and brought my own tyres, TPMS, wheels to save a lot of money. But the TPMS was an unknown. If the sensors are defective they have to take the thing apart again - more time and money. Update: I have ordered an Autel TPMS device. Once it arrives I'll try to use it to wake up the new TPMS sensors. |
26th Oct 2020 7:15pm |
Update: I got the TPMS scan tool. All TPMS sensors report air pressure on the TPMS scan tool between low load and normal load (2.5 bar front, 2.7 and 2.8 bar rear). The spare tire shows 2.4 bar. I have driven the car for hours at different speeds. I still get the yellow warning message and light and still don't see any pressure readings in the Service Menu.
2nd Nov 2020 9:35pm |
Did you physically activate the sensors with the tool? Or just read the values? You do have to specifically activate them |
2nd Nov 2020 9:45pm |
Charles do you remember how you activated them? I can scan all of them, but I don't see an option to explicitly "activate" a sensor. The manual is vague. When pressing "scan all" on the TPMS tool it shows me all of the tire pressure numbers for all of the tires. On each of them I can press the wave-button and the tool talks to the sensors again. They all have a green check-mark next to them on the tool. |
3rd Nov 2020 3:23am |
3rd Nov 2020 6:55am |
Charles I have watched the videos you posted. In the first one he uses special Autel sensors. I have Land Rover ones.
6th Nov 2020 4:26am |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 326 |
Just as an FYI, if you have a bit of computer knowledge you can also read the sensors with some free Linux software and a very cheap "Digital TV" USB stick.
6th Nov 2020 3:05pm |
Update: The problem was that the sensors I bought were not were they said. Fakes from eBay. Lesson learned - be careful about parts from eBay. Car went back to the authorized dealer and the TPMS were changed to new OEM ones at great cost. |
21st Oct 2021 6:33am |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 128 |
I have the same problem as above, the guy sent me another set Foc, had them fitted £65 and it’s just the same.
28th Jul 2022 6:24pm |
