Home > Wheels & Tyres > 275/45/20 tyres on SVD8 L405 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7808 |
They would be shorter than standard by 1" diameter, so the car would sit 1/2" lower.
22nd Oct 2020 7:41am |
FFRR64Royal Member Since: 18 Jul 2020 Location: Saltash Posts: 130 |
Thanks for the tips Alistair |
22nd Oct 2020 8:18pm |
Alistair, could I utilise your knowledge once again with a secondary question?
4th Nov 2020 8:36pm |
Sorry - no idea.
5th Nov 2020 8:25am |
Thanks for the reply and the link Alistair, the link has provided so much great info |
5th Nov 2020 4:27pm |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 86 |
Your 20" rims in the picture are marked 8.5J X 20 ...et47. which means that the rim width is 8.5 inches (8.5J) and the offset in mm is 47.
5th Nov 2020 5:43pm |
Seatown.....your description makes perfect sense, and now I can actually see the numbers and make sense of them.
5th Nov 2020 6:00pm |
There is a tolerance in the wheel width - it somewhat depends how straight you want the sidewall - there are benefits to a slightly narrower wheel in terms of protection.
5th Nov 2020 7:18pm |
Thanks for the info Alistair and for the link:
5th Nov 2020 9:17pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3697 |
Yes they will fit fine - I have a set of 285/50/20 on the same wheels - so your size will be fine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
6th Nov 2020 7:11pm |
275/45/20 are too small for an L405, they are fine for an L322 though. Personally I would (and have) go for 285/50/20, I am also sure Emperor Mong on here used to have a set of 285/50/20 Cooper LTZ’s on a FFRR - a search should find it
7th Nov 2020 9:37am |
