![]() | Home > Technical (L405) > Battery Conditioner - Where to connect |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 ![]() ![]() ![]() |
Jump post is fine sir |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 ![]() ![]() ![]() |
If you have towbar electrics you can buy an adapter to charge through there. Keith
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 ![]() ![]() ![]() |
As above, the posts under the bonnet are fine to use. Kev
Six-cylinder Member Since: 29 Dec 2010 Location: Buckingham Posts: 13 ![]() ![]() |
Thanks All it is now on charge.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7814 ![]() ![]() ![]() |
If you can be bothered, you can connect hard wire a CTEK connector to the posts
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 75 ![]() ![]() ![]() |
all those leaves are stressing me out. |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
Used an extra long cable on mine comes out top of the bonnet by the windscreen so i can connect my c-tek without opening the bonnet |
goddo Member Since: 27 Oct 2020 Location: south Posts: 78 ![]() ![]() ![]() |
I have a Cetek charger with adapter cable so I permanently connected the adapter straight to the battery. Then all I have to do is connect the charger which can sit on top of the spare wheel while topping up. |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 84 ![]() ![]() |
Service manual says that you should not connect to battery. Connect to posts in engine compartment. |
I hear what you say.
Not sure it's a problem as such - but the posts are conveniently located under the bonnet.
Historian Member Since: 16 Mar 2019 Location: Lancashire Posts: 20 ![]() ![]() |
You can as long as you connect the negative terminal to earth rather than the negative battery terminal. There's an electronic gismo in the negative wiring that monitors battery status- if you connect Ctek directly to both battery terminals it bypasses this and the BMS thinks that the battery hasn't received the charge and various 'low-battery' strategies/warnings can be kicked off as a result. |
Very strange! I have a JLR CTEK kit and guess where it connects |
palli Member Since: 27 Oct 2017 Location: Suffolk Posts: 42 ![]() ![]() ![]() |
I to have a JLR CTEC fitted in the boot to the battery. Never had any issues. 2008 Vogue Black - gone
