Home > Technical (L322) > FBH Fuse Location 2009 Facelift TDV8 |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 |
Fuse 59 behind the glovebox. 2nd in from the right on the bottom row. Take out for 30 secs, put back in
19th Jan 2021 12:04pm |
Sub5 Member Since: 19 Jan 2021 Location: Norfolk Posts: 5 |
Thanks Tugger, 59 is actually blank on mine although I put a spare fuse in here and it did nothing. I'm inclined to think it is in the engine bay but not sure which one
19th Jan 2021 12:20pm |
Very strange...should be 59. Dunno what's going on there - maybe a DIY retrofit? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
19th Jan 2021 12:24pm |
It's definitely a factory option as it comes up on the cars spec when searching the VIN code. I think the issue is when the car was facelifted (as mine is) the fuse for the FBH moved to the engine bay. |
19th Jan 2021 12:37pm |
I guess you can get the same result by disconnecting the battery for 30 secs or so, that should do the trick.
19th Jan 2021 12:40pm |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 156 |
Hi, I have a 2010 3.6 and the FBH fuse is in the boot, can’t remember which fuse it is but it should say on the panel when you remove the cover. |
19th Jan 2021 6:47pm |
Thanks I'll have a look there. I have a feeling that is for the Webasto receiver but could be wrong! |
19th Jan 2021 8:48pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 179 |
I just unplugged the unit in the boot as it’s very accessible
19th Jan 2021 9:58pm |
I think unplugging this just terminates the receiver for the key fob and may lead to having to pair the fob again. I need to disconnect the actual FBH itself... No guarantee this will work of course! |
19th Jan 2021 10:14pm |
plugging into to diagnostic would be Easier |
19th Jan 2021 10:25pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 369 |
On the facelift models the fuse for the FBH is under the bonnet, can't remember which number but there is a picture guide thing on the lid. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
20th Jan 2021 2:17pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
It's E8, I believe. 2010 4.4 TDV8 Vogue SE |
21st Jan 2021 4:37pm |
