Home > Maintenance & Mods (L405) > Battery problems |
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 |
I have spoken to a RR specialist who tells me that in some early rrs up to the facelift this is a common problem, the problem is the alternator does not always charge the battery 100% and the ecu detects this and brings on the warning, he also states that the battery are not low and should never fail to start the vehicle. This is of course that the batteries are in good orderThe problem is more noticeable in the cold weather when the drainige is high and you are not running long enough bring the voltage above the level needed to keep the ecu happy apparently there is no cure 07 Vogue SE Java Black 3.6 TDV8 Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
20th Feb 2021 5:22pm |
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 |
Hi Watty
20th Feb 2021 7:34pm |
I have had the batteries checked both ok, rr told new batteries fitted, still have the sane problem, also i do not have stop start 07 Vogue SE Java Black 3.6 TDV8
21st Feb 2021 7:01pm |
