Home > Maintenance & Mods (L322) > Why only drives side has air deflector?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi everyone,
Does anyone know why only the drives side windshield wiper has the air deflector?
Quote:
The driver's side blade is fitted with an aerofoil, which presses the blade onto the windscreen at high speed, improving the wiper performance.
Why not fit it to both sides? It's not like that one piece of plastic would cost to much to install one more.
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #584723 21st Feb 2021 6:24pm
bishbosh10
I have often wondered the same. The conclusion I reached is that it is less important for the passenger to see out the front! Laughing Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #584808 22nd Feb 2021 12:37pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Also generally the drivers side wiper is larger than the passenger side Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #584812 22nd Feb 2021 1:14pm
kevinp
And if you want to change the wiper clip on the drivers side you have to buy the whole arm because the clip is built into the spoiler. £80 a pop!! Passenger side uses normal cheapo clip.
Post #584830 22nd Feb 2021 4:08pm
lschwarcz
Kevinp,
It looks like the clip is available on it's own.
https://allbrit.de/epc.cfm?PAGE=5011605A&a...SPRACHE=EN
Check out callout number 17B473.
Bournville/Ivory
Post #584868 22nd Feb 2021 10:17pm
kevinp
Hi Larry. I bought 2 clips. Passenger side no problem. Drivers side is moulded into the spoiler. You could use the new clip without the spoiler but the blade would not then have the blade supports that are part of the spoiler. I will try and take a photo to show what I mean.
Post #584874 23rd Feb 2021 12:40am
