Home > In Car Electronics (L405) > Fitting Dash Cam
Page 2 of 3 <123>
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Many thanks Alistair.
Mine is slightly lower and more central. I’ll give it the "open air" test and hope that’s it. If not, I’ll relocate it as per yours.
Post #558753 23rd Jun 2020 6:10pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Hi all, Iam trying to fit a dash cam to my 2020 l405 but Iam at a loss when trying to lower the glove box to access the front fuse board. I fitted one to my last L405 (65 plate) but they seem to have changed the design, unless iam being a thicko but I does not seem the same, any ideas guys ? Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #587902 18th Mar 2021 4:02pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
just press the side guides, just like in this movie, at 5:53:
it's a Sport, but same thing. 2019 Vogue P400e
Post #587915 18th Mar 2021 5:21pm
Pfazz
Thanks for that I will try again tomorrow but I think it may be different set up than that. Agueroooooooooo. 93-20
Post #587917 18th Mar 2021 5:35pm
Lyonhead
Wales 2019 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Hi pfazz, i notice your car is a 2019. It might be worth contacting Range Rover Warranty to ask if its OK for you to fit your own Dashcam hard wired as it might invalidate the Warranty.
I went down the road of a security system and when I mentioned Ghost I was told that this system was going to invalidate my Warranty if any fault is found to be caused by the non LR recommended system and I also had it in writing from the LR Warranty team. So I just obtained a list of recommended systems and installers and all was ok.
I believe they think the same way about hardwired dash cams fitted if its not fitted by a LR recommended installer.
If you just plug into the cigarette lighter then obviously all is OK as its not hard wired.
Just thought I would let you know what happened when I was going down this route.
Thumbs Up Thumbs Up 19MY SVA-Dynamic Spectral Chromoflair Blue but colour not available in profile
2016 RRS SVR Estoril Blue - Gone
2010 RRS 5.0 Supercharged Navara Bronze - Gone
2008 RRS 4.2 Supercharged Black - Gone
2006 RRS 2.7 Diesel Rimini Red- Gone
Post #587943 18th Mar 2021 7:34pm
Pfazz
Thanks for that I will check before I go any further. better safe than sorry. Agueroooooooooo. 93-20
Post #587975 19th Mar 2021 8:48am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Thumbs Up Thumbs Up
Really, they invalidate the warranty for that? That doesn't sound right in accordance with consumer laws...
Post #587980 19th Mar 2021 9:41am
Martin2
Porsche invalidate the warranty if you don't put N rated tyres on! MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #587988 19th Mar 2021 10:25am
Rob99
I'd like to see that stand up in court....... Laughing Laughing 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #587991 19th Mar 2021 10:37am
Martin2
It's in the T&C's. Their batteries are (were?) terrible, not even sealed and only last a couple of years but we had to put another in for the same reason. MY23 Panamera E-Hybrid
Post #587993 19th Mar 2021 10:43am
Bl4ckD0g
Just because it is in the T&Cs doesn’t mean it’s legal and enforceable.
But to be balanced, that also works the other way around. Just because one may have consumer laws behind them that doesn’t mean it will be an easy path to get issues sorted.
So ultimate it all depends on ones risk appetite and willingness to state their claim and make it. And a little bit of common sense. For example in the case of a dashcam installation, if you then have a problem with radio dab reception and the camera wasn’t installed by Land Rover then they could rightfully suggest that you’ve invalidated that part. Just as an example.
Post #588010 19th Mar 2021 1:30pm
Rob99
Now that you can buy a Land Rover dash cam from JLR concerns about warranty issues should be moot, as they would be for any other approved accessory 2017 4.4 SDV8 Autobiography
Post #588019 19th Mar 2021 2:31pm
Bl4ckD0g
Possibly. That LR Dashcam seems to be quite old tech and resolution. I have no evidence, but it seems like an entry level thinkware rebadge to me but for top of the range prices.
Post #588020 19th Mar 2021 2:37pm
As an aside..
Just been browsing on PowerfulUK and they do a plug and play loom piece for the overhead console, which splits out a + and - battery feed from the loom. Which makes wiring a dash cam to the top console a lot easier. would still need a stand alone fuse I think but saves actually cutting into the loom.
https://www.powerfuluk.com/vehicles/range-...nsole.html There is nothing that can't be fixed with a hammer😜😜
Post #588275 21st Mar 2021 5:29pm
thats a good spot Mark..just neds converting down to 5volts and you're good to go,
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #588281 21st Mar 2021 5:47pm
Page 2 of 3 <123>
