Home > Technical (L322) > Battery disconnected - all faults cleared? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
When does it drop into reduced performance, any particular thing you are doing..?? Pete
23rd Mar 2021 10:03pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 528 |
Nothing, it's completely random, and when it first started doing it there was no discernible drop in performance either - but then it seemed to get worse. I pulled away from some lights, not that hard, and it bonged and threw the Reduced Performance message and nearly stood on it's nose with the loss of power! That was when I stopped using it, it's now with a decent indie (AHL) but they can't read any faults from it. 5.0 S/C Autobiography
23rd Mar 2021 10:15pm |
Mine started to do that but only when at full throttle (mostly), showed no codes and the reduced performance reset by restarting it... It did it numerous times before it left a fault code P0087 low fuel pressure...
23rd Mar 2021 10:48pm |
Mine sometimes bonged and said reduced performance but ran fine with no loss in power... I think your problem sounds similar to mine... Pete
23rd Mar 2021 10:50pm |
It does indeed Haylands, thanks for this. If the garage don't/can't find it this week I'll have to monitor, knowing that the IID will pick up your symptoms is helpful to know. 5.0 S/C Autobiography
23rd Mar 2021 11:09pm |
