Home > Maintenance & Mods (L322) > Battery? ECU? Help |
thrillcat Member Since: 04 Jan 2018 Location: Ames, Iowa Posts: 23 |
Okay, I'm here, and I need the brain trust. I've had a 2012 RR HSE for about 3 1/2 years now, outside of some suspension replacements and oil changes, I've had no issues. That changed tonight.
7th Apr 2021 3:20am |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 927 |
All sounds like typical alternator symptoms too me mate. Go to your local hardware shop and get a multimeter and check the battery with that. If the alternator is dead it could easily kill the battery and throw up all the faults. Start with the cheapest and work your way around the starting point |
7th Apr 2021 2:29pm |
MarcoPolo Member Since: 07 Dec 2018 Location: Preston Posts: 19 |
Another possibility could be that the plates in one cell of the battery warped then came into contact with each other. This 'kills' that cell and, because all six cells are in series, renders the battery almost useless. I've had this happen overnight on a different vehicle (not a RR) with a relatively 'young' battery and got pretty much the same result - battery great when I put the vehicle away for the night, and dead the next morning even though there was no drain whatsoever on the battery.
7th Apr 2021 5:41pm |
Thanks everyone for the help. I had time to work on it this afternoon, so I disconnected the battery and let it sit for 30 minutes. Tested at 12.3v at that point. Connected it back up and everything started up and functions perfectly.
7th Apr 2021 10:03pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
WOW RR 2005 4.4 petrol
8th Apr 2021 3:53am |
