![]() | Home > Technical (L322) > Tdv8 L322 2012 no crank, no power to starter solenoid |
afyy27 Member Since: 09 Apr 2021 Location: Mombasa Posts: 12 ![]() ![]() ![]() |
I forgot to mention, once I started the car by applying external voltage to solenoid the brakes are low and hardly working. I suspect the brake light switch too but brake lights are working fine. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2329 ![]() ![]() ![]() |
The starter relay is relay 6 in the engine bay main junction box, with power supplied by fuse 10 (40A) in the same junction box.
Mine has an auxiliary fuse panel inside the main panel on the engine end so I wonder if the vehicle is 2012.
Thanks. Yes this also has another smaller fuse box beside the bigger one. It doesn't show in the picture. |
Does the VIN end with BA or CA followed by 6 digits or does it end with AA then 6 digits? |
It ends with AA |
Today I swapped the starter relay and checked all fuses. Everything is OK except the car still won't crank when I press ignition switch. I have a Launch x431 and checked for any trouble codes. None are there except lost communication with ABS module in Srs system, Left puddle light signal error in Passenger door control module. There is absolutely nothing related to the starter.
Anyone? No one? |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Are you able to confirm that the starter button isn't faulty? 2011 TDV8 Vogue SE |
I don't have a spare button to test but when I read datastream it does register the the button clicks. Once when I switch on and when I depress Brake pedal and press it. |
Just now I thought of going through the BCM module with my scanner. I went into actuation test and gave a crank request signal and voila! The car starts from the scanner but still won't start from pressing the ignition button. |
The stop/start button has multiple contacts so one set may have failed.
Most probably it's the 2010 model. My mistake. I'll just look for a replacement button and hope and pray it's the problem. I was crawling the web for the same problem and some people with similar problems suggest the car might have gone into lock mode as I tried to access the car by giving voltage to the starter. The funny thing is there are no trouble codes at all in the immo and key receiver module. Do u think I might need to hook it up into JLR Sdd software? |
