Home > Maintenance & Mods (L322) > Problem dismantling air suspension leg to fit new air bag |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
Old style -14mm allen key and add length with a bar / piece of pipe onto allen key, apply force and then give it sharp bloody hard blow with a lump hammer to break the tension. Just make sure the recess is spotless to stop the allen key slipping out. |
16th Apr 2021 6:30pm |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 25 |
Thanks.
16th Apr 2021 7:18pm |
As you have the 1/2 inch drive 14mm allen, use that on a 1/2 inch drive breaker bar,500 or 600mm (Quite cheap) then use said lump hammer. Screwfix / toolstation 600mm B/Bar for £20
16th Apr 2021 9:03pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
Good thread here: https://www.fullfatrr.com/forum/topic47064-15.html Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
17th Apr 2021 6:57am |
18th Apr 2021 12:09pm |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 231 |
Land Rover refer to it a an isolator or damper fitted to vehicles with High Performance Brakes. Helps with resonance under braking. |
18th Apr 2021 12:29pm |
Thanks. I will see how the car handles before deciding whether or not to buy some replacements.
18th Apr 2021 1:02pm |
I tried the brute force method as well, I have a impact gun that takes a lorry wheel nut off without a complaint and happily undid the crankshaft bolt on my old TD5.. but wouldn’t budge this, researched the loctite in the LR manual and realised to release it needed heat. Heated it up with some shields to protect everything else and it just spun off by hand Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
18th Apr 2021 1:54pm |
They are around £120 each new and very difficult to find pre owned. |
18th Apr 2021 3:28pm |
I've been describing this device as made of aluminium. It's not. It is most definitely steel.
18th Apr 2021 9:17pm |
