Home > Maintenance & Mods (L322) > What is the actual diesel MPG? (2012 4.4 TDV8) |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 |
V Power diesel here is about £7.02 a gallon, which would put you at 18 mpg. That’s 10% better for you…. |
23rd May 2021 3:45pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
That sounds really low to me. I don’t check mine, mainly as I can’t figure out the over complicated 3 averages thing that the computer does.
23rd May 2021 4:14pm |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Yeah that’s low! I recently posted about getting 400 miles to a tank which I thought was low - many posts on here averaging 30ish 1995 4.6 v8, green/tan (long gone)
23rd May 2021 4:26pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 307 |
. thank you! that's really helpful. I will adjust my post. |
23rd May 2021 6:02pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 344 |
I’m averaging about 25mpg but short trips circa 8 to 10 miles that’s on normal unleaded generally BP. Not helped by hills around here....main use involves a 3/4 mile long drag as soon as I start.
23rd May 2021 7:21pm |
If it helps, on my l405 4.4 diesel, if I do motorway driving at 60mph I get about 24-26mpg. If I do motorways at 80 I get 33mpg. My car wants me to have fun….
23rd May 2021 8:27pm |
Not sure it gets in to top gear at 60mph.... wonder if changing up manually on paddles helps with mpg...?
23rd May 2021 8:52pm |
That would explain my mystery consumption, and I will try the paddles next time I feel like a leisurely (or hungover) motorway ride |
23rd May 2021 9:06pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 225 |
Car usually says around 30 mpg but filling brim to brim shows real world consumption is between 25 and 28 mpg.
24th May 2021 8:08am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Calculated over 70,000 miles I averaged 17.14 mpg but a lot of that was towing 2000 kg of caravan.
24th May 2021 8:18am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
19mpg sounds way too low for the 4.4TDV8 engine, assuming it's not in Sport mode and you're not driving it like you stole it
24th May 2021 9:24am |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 719 |
I have an L405, so not exactly the same, but over 11,000 miles I've averaged 27.8mpg. That's calculated, the computer is just over 7% optimistic. I do quite a lot of decent length journeys, if all I did was potter around town it wouldn't be much above 20mpg. Best brim-brim has been 31.1mpg and I have seen around 35-36mpg on the computer on long motorway journeys which would have been around 33mpg.
24th May 2021 9:50am |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
That does seem low fuel economy...
24th May 2021 9:55am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
like Rob i was getting high 20's around town and low 30's on runs with my westie..
24th May 2021 10:00am |
