Home > Technical (L322) > Help Sliding pin spanner size? see500020 Front brake removal |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
13mm for the bolt, 16mm for the sliding pin. First make sure you scrape / brush off any rust / scale that may have built up on the flats. |
1st Jun 2021 9:59pm |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
Your a gent!
1st Jun 2021 10:14pm |
If you cannot find a 'skinny' spanner, buy a cheap one and use an angle grinder, file or similar to reduce the thickness. Hope it all goes well |
1st Jun 2021 11:13pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 |
As above, i have a slim set of spanners for this... |
1st Jun 2021 11:55pm |
16mm is too small.
2nd Jun 2021 5:20pm |
A 17 fit it in the end.
2nd Jun 2021 7:58pm |
Ah well, at least you got there, my bits are all Pagid, must be slight differences in sizes, typical RR problems |
2nd Jun 2021 9:18pm |
