Home > Maintenance & Mods (L405) > strange whine |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 215 |
Could be a split turbo hose? Sounds like when you plug a blade of grass between ur hands and blow?
21st Jun 2021 10:26pm |
aguiness Member Since: 13 Jan 2021 Location: glasgow Posts: 36 |
Its going in on the 16th for a service and also the oil sensor in the sump issue ill get them to check thanks |
21st Jun 2021 10:29pm |
Is it anything like this?
21st Jun 2021 10:36pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 |
The diffs can condensate and then the main bearing can whine under load... Have you ever checked the oil condition? |
21st Jun 2021 11:33pm |
I havn't checked the oil yet. you dont hear the noise when free wheeling only when the accelerator is pressed and driving. |
22nd Jun 2021 9:58am |
Exactly… |
22nd Jun 2021 11:55am |
Sounds like diff or driveline whine to me too. Had the same problem in our old hilux, diff whined under load, then squealed, then made horrid noises. New diff required, so a quick change of diff oils and see how it goes. There is nothing that can't be fixed with a hammer😜😜
22nd Jun 2021 4:53pm |
Great thanks |
23rd Jun 2021 3:08pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
Any update? My 5.0 SC whines between 70 and 75 mph when applying power. Not at any other time. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
13th Sep 2022 5:38pm |
Hi
21st Sep 2022 10:15am |
