Home > Technical (L322) > 4.4 TDV8 Oil Consumption |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4254 |
Seems a bit much. I think 1 notch is 150mL Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Jun 2021 6:28pm |
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 |
Mine drops a couple in about six months, approx 2500 miles. Though I do a lot of 6 mile trips to work and perhaps cancelled DPF regens fill it up a bit with diesel ? Not sure |
29th Jun 2021 10:12pm |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 |
Mine uses no oil whatsoever between 6k oil changes. Typical use is around town 3 mile trips to and from office Monday to Friday - An occasional 100 to 20 mile trip every other weekend or so and every 3 months a round trip of 3k miles to the UK from Eastern Europe, which includes high speed runs through Germany on the way to and from the UK. 2012 4.4 TDV8 Vogue SE Current
30th Jun 2021 6:38am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 444 |
Have you checked for leaks? It’s not unheard of but unusual for them to burn oil. Check around the oil cooler in the V of the engine, also less likely the oil pump has been known to leak from a large plug located on the top of the pump itself, The pump bolts on the front of the engine and is driven directly if the crank.
30th Jun 2021 7:14am |
I had all 3 = oil leak bingo
30th Jun 2021 8:11am |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 225 |
Thanks to all for the advice. I think I have to be more methodical with my checks, as the level is up a notch today. I’ll ensure exact same level position and timing after engine off for future checks.
30th Jun 2021 3:23pm |
