Home > Technical (L322) > P2264 - Water in Fuel Sensor Circuit - 2011 4.4 TDV8
Page 2 of 3 <123>
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
So the sensor and associated wiring have solved the issue for £39 rather than the £250. Shame to throw the rest of the stuff away but just happy it’s working.
Post #570667 22nd Oct 2020 5:03pm
kooky_guy
I've got this exact same problem - finally managed to capture the fault message and it's P2264-00. Like others, there seems to be no apparent loss in performance and it's very intermittent.
Is there any more information on how to replace the sensor? BB's image isn't there any more - was that the workshop manual diagram?
Who is 'Maltings'? 2010 4.4 TDV8 Vogue SE
Post #573786 23rd Nov 2020 9:35am
Gr4h4m
Maltings are a supplier, they have an eBay page and sell land rover parts.
When you order the filter and housing you will see the sensor which it screwed to the back, they’re are two leads that come from it one plugs into the loom the other pushes onto the bottom of the fuel filter. The fuel filter can be seen from on the right hand side of the engine bay. It’s held to the body with two bolts IIRC, you need to undo them and move it toward to replace/remove the sensor and wiring.
Post #573789 23rd Nov 2020 10:07am
kooky_guy
Thanks. I assumed that's what they were. I'll see if I can find them.
Appreciate the info. Will have to see if I can find it. 2010 4.4 TDV8 Vogue SE
Post #573790 23rd Nov 2020 10:10am
rjff
https://www.maltingsoffroad.co.uk/ Cheers
Richard
Gap IIDBT
Post #573820 23rd Nov 2020 3:35pm
Doug86
I've got the same issue! Speaking to Maltings they suggest this as a fix:
https://www.ebay.co.uk/itm/254752203698?ha...SwSjpfjAmO
Any fitment guides?
Post #595532 27th May 2021 5:12pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
If I'm reading this right Maltings sold the part in 2018 for £10, then in 2020 it cost £39, now the price is £69.99
That's some rate of inflation 2011 TDV8 Vogue SE
Post #595591 28th May 2021 7:29am
kooky_guy
Wish I had bought one earlier! It's still much cheaper than the complete housing.
So I've ordered one as my fault is coming up more and more frequently. Just got to work out how to fit it! 2010 4.4 TDV8 Vogue SE
Post #596804 8th Jun 2021 10:33am
Doug86
Will you be taking any pictures as you get it fitted? Very Happy
Post #596867 8th Jun 2021 8:42pm
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
I had the same problem sensor saying water in system etc
when checking cable that connects to base of filter the connector was broken couldn't find a cable at that point so decided to buy a complete 3.6 filter housing and used cable of that
the cable is about 2 inch longer but connector is the same and when fitted you have a larger loop but only you would be able to tell
might be a way to go as a lot cheaper if it fixes the issue
Post #596902 9th Jun 2021 8:24am
Tattiepicker
United Kingdom 2011 Range Rover Vogue TDV8 Mariana Black
I have just replaced my sensor, but I believe it was just the drain cap off the bottom that was wrong for me. I have the guts of a wiring harness if anyone wants?
Post #610623 27th Oct 2021 5:23pm
Doug86
Can anyone share the part numbers for the various fixes?
Post #610807 28th Oct 2021 5:02pm
rjff
It may be worth looking at the ebay site for Maltings
If ( a big if) I'm correct the 3.6TDV8 unit has the same sensor as the 4.4 although the filter and housing are different and their ebay site shows that complete unit at £39.99. but on clearance. It may be the details are not as they seem on the site, but worth a punt to speak to them about that unit.
HTH and let us know the outcome. Cheers
Richard
Gap IIDBT
Post #610842 28th Oct 2021 8:10pm
kooky_guy
This was the one I bought. Fixed my problem:
https://www.ebay.co.uk/itm/RANGE-ROVER-TDV...635-2958-0 2010 4.4 TDV8 Vogue SE
Post #610850 28th Oct 2021 9:00pm
gotters
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Santorini Black
Matings all out of the £70 sensors linked here now, but called them and they were very helpful, saying that they have another identical sensor which they can provide, so got that on the way.
Is changing over the sensor a simple plug and play job a novice could attempt ?
Post #625136 2nd Mar 2022 11:48am
Page 2 of 3 <123>
