Home > General > 3.0 td6 - worth a shout? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
Irrespective of how engines etc compare….
28th Nov 2021 10:10pm |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 443 |
Very different vehicles in some ways. The gearbox is the weak point on a td6, you get the older style dash, mpg is c.22/25 vs 30mpg for the 4.4tdv8, if you go pre 2006 on the td6 tax is cheaper at £340/yr, acceleration is 12am slow to 60 vs sub 8.0 for the 4.4tdv8.
28th Nov 2021 10:11pm |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
I've been the proud owner of a 2005 TD6 for 10 years . LOVE it.
29th Nov 2021 5:09am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
I have run a 2005 TD6 as my daily drive since February 2019 and it hasn’t missed a beat. I have had to replace the front lower arms and a couple of bushes but that’s it apart from regular servicing.
29th Nov 2021 10:57am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
^ £6500.00, you've just made my day. |
29th Nov 2021 11:06am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Had my 02 TD6 for 11 years now . 2 previous owners and was 123k miles when I got it and now on 167k so don't do a lot of mileage. It has never had a tow bar fitted and is on it's original gearbox . First thing I did was a fluid and filter change when I got it . Some (but not all) first GM boxes didn't have the issue with the alloy blocks wearing and causing issues and it looks like mine is one of them (fingers crossed) . In my ownership it has had the dreaded rear jacking sill corrosion on both sides re fabricated (£2k) , front prop shaft coupling (1k - missed the recall by 1 week and JLR were not interested !) , replaced carbon brushes in the alternator , replaced starter motor and 2 x diesel injectors along with fitting the vortex oil filter mod for the turbo . It is , I found out , tuned with an add on tuning box fitted . Apart from that and routine maintenance and WaxOyl (think of the forth road bridge - never stops lol) it's a fantastic car and stands on a Ctek MXS10 charger in the drive for when it's needed . If anyone is looking at purchasing a potential TD6 , or any car for that matter , I would recommend putting the registration number in the government web site and look at the vehicles MOT history - it can be quite an eye opener |
29th Nov 2021 11:21am |
Oh , forgot to add , also had the main thermostat by passed with the renault in pipe mod , rather than strip the engine apart to replace the original |
29th Nov 2021 11:23am |
