Home > Maintenance & Mods (L405) > Rear lens replacement L405 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
you'll have to soften the bonding between the lens and light unit to remove it..
13th Dec 2021 1:28pm |
Pendle Member Since: 12 Dec 2021 Location: Hampshire Posts: 23 |
Thanks
13th Dec 2021 1:34pm |
a strong clear silicon glue will do the job..there are many brands available.. ... - .- -.
13th Dec 2021 1:35pm |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 43 |
There’s a video on the PowerfulUK site in which they “de-tango” some D3 headlights, swapping out the orange reflector for a clear one, by placing the headlights in an oven to soften the adhesive and separating the lens from light body.
13th Dec 2021 2:18pm |
Thanks Matt
13th Dec 2021 3:55pm |
Hi Matt
13th Dec 2021 4:44pm |
Thanks Matt
13th Dec 2021 4:47pm |
AND !!
13th Dec 2021 4:51pm |
Oh, sorry, I should have posted the link…but you found it in the end
13th Dec 2021 5:29pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
I’m not sure the rear light lenses are as straightforward to replace as I think they’re plastic welded opposed using mastic which can be softened with heat per the headlights.
13th Dec 2021 6:16pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Yes, they are sonic welded together... I would simply break the old cover off bit by bit Careful NOT to touch any chrome inside as it'll be ruined by the oil in your skin... Then glue the replacement on using some form of PU |
14th Dec 2021 1:34am |
Thanks Cam'
14th Dec 2021 10:42am |
have you considered looking on ebay for a replacement light unit...you might lucky and find cheap one.. ... - .- -.
14th Dec 2021 11:25am |
Muiryden Member Since: 28 Feb 2017 Location: Highlands Posts: 2 |
No disrespect to PowerfulUK, great company I have used many times and I just love the videos!! However I replaced the lense on my L405 a few weeks back. Spent at least 3 hours on it and wasnt happy with the end result as you are effectivly guessing where to re-bond the new lense. I would go 2nd hand route. |
28th Jan 2022 12:09pm |
