Home > Technical (L322) > TDV8 inlet manifold change |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
If anyone needs a little help here on the intake manifold replacement I have just replaced drivers side on the V8 tdi L320. |
4th Jan 2022 12:51am |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 199 |
Anyone find that it’s not just number 8 that’s a struggle? Number 4 is also fouling the body but I don’t see this reported anywhere- is my car special? 😂 2007 TDV8 Vogue SE
18th Jan 2022 11:01pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Same as the left side, apparently lift the engine after undoing the engine mount. I have put off changing my gasket as it's stupidly hot here plus after an oil change using 10w40 oil ( specified for hot climates ) the leak has all but stopped. 2007 TDV8 VSE
19th Jan 2022 1:09am |
amjg123 Member Since: 24 Feb 2023 Location: South West Posts: 1 |
Know i'm digging up an old thread hear! :S Interested to know if this lasted long as investigating a boost leak code P023D(22) and going to check if its the intake tomorrow when its daylight. if it is I will definitely be trying sikaflex for a temporary repair. |
24th Feb 2023 1:08am |
I had to split the injector to get number 4 out as I couldn’t get near the engine mount bolts! 2007 TDV8 Vogue SE
24th Feb 2023 10:02am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Thought id reply to share my experience (still having flashbacks like nam) on these latest replies.
24th Feb 2023 10:44am |
Ah, so you need to remove the arch liner- I wasn’t sure if removing that would help much, ok- good to know
24th Feb 2023 10:59am |
