Home > Technical (L322) > New TPMS sensors not being recognized
Pysta
Slovakia 2011 Range Rover Vogue TDV8 Fuji White
After acquiring a new set of wheels and tires, I reckoned it might be the best for the long run to replace the TPMS sensors as well.
Bought a set of JLR badged Continental sensors from Nov 21 based on my VIN - my previous ones being FoMoCo - and assumed they would map automatically after a couple dozen miles.
Lo and behold, they did not, even not after longer trips so I started searching for the mapping process for which the general consensus seems to be "there is none".
SDD has a sensors identfication mapping screen where you have to add the sensor IDs for all 4(5) wheels. After submitting the values the system still requests at least a 15 minute delay with the ignition off, and the classic 20 minute initialization drive afterwards ... after which I'm getting a yellow TPMS Fault, and the ecu doesn't seem to be able to see any of the sensors.
Normally it would seem I have bought 4 duds, but an external TPMS reader can view the TPMS status and pressures in no time.
Did anyone have a similar issue ... and found a fix?
Post #620473 18th Jan 2022 8:28pm
its possible you have a vehicle that reads 315mhz frequency tpms and the ones you have in the wheels are 433mhz.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #620496 18th Jan 2022 9:29pm
Pysta
Yes that was the first thing I checked for, but the old ones were 433 and based on the screenshot he's looking for 433MHz units as well
Post #620528 19th Jan 2022 7:49am
Kot
On L405 you need to program new sensors into system see below WS manual presume L322 will be same?
From WS Manual
As different pressure targets and thresholds for the front and rear tires, the Tire Pressure Monitoring System (TPMS)
can identify the location of the tires. The TPMS system then assigns received tire pressure sensor identification to a
specific position on the vehicle. For example: front left.
The TPMS locates the position of the tire automatically. This function requires no manual intervention by the driver.
The TPMS automatically learns the position of tires on the vehicle if the tire pressure sensors or their positions are
changed on the vehicle.
The tire learn and location process is ready to start when the vehicle has been stationary, or is travelling at less than
20 km/h (12.5 mph) for 15 minutes. This is known as 'Parking mode'. The learn/locate process requires the vehicle to
be driven at speeds of more than 20 km/h (12.5 mph) for 15 minutes. If the vehicle speed reduces to below 20 km/h
(12.5 mph), the learn process timer is suspended until the vehicle speed increases to more than 20 km/h (12.5 mph),
after which time the timer is resumed. If the vehicle speed remains below 20 km/h (12.5 mph) for more than 15
minutes, the timer is set to zero and process starts again.
The TPMS can automatically detect, under all operating conditions, the following:
If 1 or more tire pressure sensors have been replaced.
If 1 or more tire pressure sensor identifications are missing.
If 1 or more ‘alien’ identifications are being received (the TPMS will reject these signals).
DESCRIPTION
Identifications from tire pressure sensors that do not belong to the vehicle.
If 1 of the tires in use on the vehicle have exchanged position on the vehicle.
If 1 or more incompatible tire pressure sensors have been installed.
If the tire pressure sensors installed to the running wheels are changed, the TPMS can learn the new sensor
identifications automatically. The learn function requires no manual intervention by the driver.
The RF transmission from the sensor contains a unique identification code in its transmission data, so that the TPMS
can identify the tire on the vehicle. If the sensor is replaced on a ’running’ wheel, the identification for that sensor may
be programmed into the TPMSCM using a Jaguar Land Rover (JLR) approved diagnostic equipment. That wheel is
not monitored until it is programmed, or until the wheel is learned by the vehicle, which can take up to 15 minutes. The
identification code is on a label with the complete wheel and tire assembly when new and is printed on the casing of
each sensor. 2018 SE SDV8 4.4 Byron Blue
Post #620556 19th Jan 2022 11:06am
Pysta
Thanks Kot, the procedures are pretty much the same on the L322 as well, and I have been through with them a couple times already.
One interesting thing was mentioned in Autodata, that a bad alternator might cause this issue as it's interfering ... to which I said nah, the old ones worked fine ... and the next day I was greeted by an RP and Not Charging dash Rolling with laughter
So let's see what the new alternator does here
Post #620713 20th Jan 2022 6:08pm
