Home > Technical (L322) > Slipping gearbox - S/C |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2985 |
That’s a strange fault.
16th Feb 2022 11:46pm |
lewis93 Member Since: 23 May 2017 Location: kent Posts: 27 |
Will be getting codes read tomorrow. IID tool is shared between 3 of us, all s/c L322!
17th Feb 2022 12:11am |
So… driving the the brothers house this evening I had a bit of time to explore the fault and turns out the gearbox is slipping in 2nd gear. Runs fine in 1st and 3rd and only happens high in the rev range. The garage I bought the car off had the trans oil cooler/line replaced as this is apparently a common fault due to them rubbing together. I am hoping it’s just a simple case the garage has either not topped of the trans oil enough or used the wrong oil. Going to buy a couple of litres tomorrow and top it up. In the meantime I’ll try and book in for a mega flush and hope it does the trick ! |
18th Feb 2022 12:22am |
Make sure you top it up with the engine running and the temperature around 40 degrees.
18th Feb 2022 5:39pm |
Thanks for the reply David.
18th Feb 2022 6:16pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
The friction elements used for 2nd gear are the A clutch and the C brake.
18th Feb 2022 7:43pm |
Haven’t tested 6th Gear Phil. After discovering it was a fault with the Trans I drove home like miss daisy and have left it since….
18th Feb 2022 7:47pm |
Was the 2nd gear error a gear monitoring fault (P0732) or a gear load fault (P0782)?
18th Feb 2022 8:08pm |
Phil, it was a wrong gear ratio fault that came up on the IID |
18th Feb 2022 10:26pm |
UPDATE:
27th Feb 2022 11:08pm |
