Home > Technical (L322) > Clattering Noise When Turning ( Coming from NSF ) |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 |
Folks,
9th Jun 2009 10:44am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
Sounds like a bearing type joint breaking up maybe? I'm not sure what they call it these days, used to be a CV joint, or known as a Wheel bearing in normal cars I think.
9th Jun 2009 7:29pm |
Thanks Guys appreciated. I'll keep you posted.... 2005 Audi A8 W12
10th Jun 2009 10:19am |
Well, one week on and 2 days in the local Land Rover dealer and still the same problem. The drive shaft has been changed and apparently there was a recall/mod on the early LR322 models which involves modifying the front diffs. Not sure if anyone is aware of this. This was thought to be the cause of the problem, but no
17th Jun 2009 8:12pm |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 |
Yes, was a well documented problem with the BMW transmission - front diffs/final drives req'd modifying...
18th Jun 2009 2:01am |
jonny142 Member Since: 29 Oct 2008 Location: Sheffield Posts: 28 |
Hi there, I had a similar problem, turned out that i needed a new steering rack. Local steeler charged me £1100. Cheaper on Ebay 4.4 V8 Vogue Adriatic - Cream leather |
18th Jun 2009 5:15pm |
Thanks Jonny, dealership still recon its the 'clips' at either end of the drive shaft ???
23rd Jun 2009 4:01pm |
