Home > Technical (L322) > One touch Window Closure |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 444 |
Hi Jon, have you tried a reset? Send the window all the way down then hold the switch in the down position for 10 secs. Send the window all the way up and hold the switch in the up position for 10 secs, this should reset it, unless the switch on the passenger door is faulty. |
22nd Mar 2022 10:59pm |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 |
Cheers Dave I’ll give that a try tomorrow 👍 |
22nd Mar 2022 11:01pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 309 |
I'm sure it all does the same thing, but this is what worked for me.
22nd Mar 2022 11:18pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
If it works from the drivers side but not the passengers side then its almost certainly going to be the passengers switch at fault... |
23rd Mar 2022 12:36am |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
One touch windows can be learned one side at a time with IID to save all the lifting a button messing about. Christian.
23rd Mar 2022 12:39pm |
