Home > Wheels & Tyres > Polished Wheels 'Style 12'
RRABNara
2012 Range Rover Autobiography TDV8 Nara Bronze
Our RRAB 2011 tdv8 is fitted with Style 12 chrome polished wheels ( see image )
I was wondering if those wheels are chrome painted or are really bath chromed, as we need to refurbish them
Thanks
Post #627895 6th Apr 2022 10:02am
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
Pretty sure these will be media polished, opposed plated / painted etc Thumbs Up
Post #627922 6th Apr 2022 1:23pm
RRABNara
what do you mean for "media polished" ?
will you be so kind to explain the process?
thanks
Post #627939 6th Apr 2022 2:54pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Are they not diamond cut and lacquered? Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #627940 6th Apr 2022 2:59pm
RRABNara
no they are not diamond cut as you cannot see any "ray" tipical of diamond cut
they looks silver painted or chromed
also it is impossible to diamond cut with the engraved "Range Rover" written
Post #627946 6th Apr 2022 3:29pm
Caesium
As the Range Rover is recess cut into them and diamond cutting is 1/1000ths of an inch material removal they absolutely can be diamond cut.
Diamond cutting is a generic term for lathing the surface off, polishing and then lacquering. Christian.
Current Cars
2019 BMW X4
or
Post #627947 6th Apr 2022 3:32pm
CS
My 2012 WM had the same. They are polished and then lacquered. Alas the finish is prone to getting 'runs' of corrosion under the lacquer. I had the first set replaced under the corrosion warranty when that happened, but it was not long before the second set started to go the same way. The sparkle silver painted alternative might be more durable, but if you like the look then i suspect you'll need to keep refurbishing them fairly regularly. Only Range Rovers since 1988
Post #627953 6th Apr 2022 4:23pm
JCW
thanks
As an example, here’s a company that performs this type of work - no connection whatsoever!
https://www.ebay.co.uk/itm/181591457667?_t...BMiKWA__9f
Post #627977 6th Apr 2022 6:35pm
