Home > Technical (L322) > Charging issue? 4.4TDV8 |
mezo Member Since: 13 Mar 2022 Location: Milton Keynes Posts: 21 |
Been chasing what i think is a battery drain issue - I dont use the car daily, so the voltage slowly drops down to about 12.5 when asleep, unlocking the car (which pulls 15a) will pull the battery down to around 12.1 - 12.3 volts and it appears that anything less than 12v it will refuse to start.
14th Apr 2022 10:36am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2786 |
AGM battery will need registering to update the charging behaviour. 2012 TDV8 Vogue (L322) |
14th Apr 2022 11:58am |
Seems to be getting worse - at idle now it wont charge at-all. If you bring the revs up to about 1500rpm it will suddenly kick in.
23rd May 2022 9:10am |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Check the belt/alternator. Other things to check and fix would be earting and bad contacts.
23rd May 2022 10:14pm |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 183 |
Mezo, I’m having exactly the same with mine, also using the same Bluetooth battery monitor. I’m not sure this is an issue as, despite it seeming like very abnormal behaviour, at no point has the battery warning light on the dash come on, which would be the point that the vehicle thinks there’s a problem. It still leaves me anxious to see the charge get so low, so am monitoring closely to see how it pans out. I have narrowed it down to be most likely either bad earthing points or a problem with the battery monitoring system (BMS). Here’s what I’ve done so far, all in the last 3 months:
23rd May 2022 11:21pm |
Andy, I had the same issue before and have done all of the mods you have done plus a new BMS. Replacing the BMS did not help (bad BMS will show on the dash). My charging has improved(may be fixed), but I feel there is a persisting underlaying issue that will pop up again.
23rd May 2022 11:51pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
I think you're looking for a problem that doesn't exist, many manufacturers have used 'smart charge' systems for some time, where the voltage is lowered to reduce load on the engine - mainly for reduced emissions, it's not uncommon to see a system voltage of 12.6VDC with a battery at >70% SoC, provided the voltage rises when the battery is discharged, most commonly after repeated engine starts or the external temperature is low, then everything is OK.
24th May 2022 7:31am |
ffrr14, really helpful as always! 👍
24th May 2022 7:58am |
Jesus your charging profile is like mine - started at close to 13v and ended up less than when you started. I'm pretty sure that my car always went up to 14.7+ volts at idle until recently.
24th May 2022 8:46am |
Belt is fine - replaced the tensioner recently because it had collapsed and belt was running of the edge. I'll measure the voltage difference between the engine and battery negative post to check earthing. The starter mod is interesting. Once you unlock the car I get about 15amps of drain which pulls the battery down to about 12.3volts - anything less than that and the car will refuse to even try cranking |
24th May 2022 8:51am |
Yes I'm aware of the smartness of the charging system. I owned a e65 7 series and the charging system is very well documented. I cant datalog current draw when on the move, so the voltage monitor is the best i can get for on the move. You can see in the video i posted, i'm using a current clamp to prove what's going on. I've also got a current shunt to measure down to milliamps for parasitic draws, but i've parked that problem. I read in the workshop manual that you measure the voltage and commanded PWM from the ECM to determine if the alternator is duff or not. Given the graph posted by the other poster is almost identical to mine, i do wonder if i'm chasing a shadow. |
24th May 2022 8:59am |
Yes i keep getting failure to start when the battery voltage is getting low - usually about 12.6v before the car wakes up, which takes it down to 12.2-3v when woken up - then it wont start. maybe i chasing my arse worrying about the alternator. |
24th May 2022 9:08am |
I am loving the mod and the car now. Anxiety around starting is gone now, and I am beginning to enjoy the finer things like HD sound wafting suspension and "the power" is mesmerising
24th May 2022 11:38am |
Mezo, I wholeheartedly agree with ffrr14 ref the starter mod. There’s other more detailed threads on here but to try and summarise (also acknowledging GraemeS’ contribution on this from a previous conversation I had with him):
24th May 2022 5:48pm |
