Home > Maintenance & Mods (L322) > Oil change interval for prolong short distance driving? |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
Hi Guys
24th Apr 2022 10:46pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
I do a mid service change at 6 months using a Draper vacuum pump. Loads of info on here about it. Use the Search function Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Apr 2022 8:29am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1108 |
Lol I do the dog run etc and do about 8k per year nearly all short journeys in Norfolk .
25th Apr 2022 10:08am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2780 |
You can get all the oil dilution, DPF info etc via the GAP IID tool. 2012 TDV8 Vogue (L322) |
25th Apr 2022 10:12am |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 223 |
What is a good/bad oil dilution figure? Mine was 3.7 before it went in for its annual service after 4.5k miles. 2011MY 4.4TDV8 Autobiography Baltic Blue
25th Apr 2022 2:06pm |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
Can we check oil dilution value for l322 using IIDTool ?
25th Apr 2022 2:38pm |
It's in the live values for the engine. It's only a concern if you are doing high miles and stretching the service interval as it's dependent on DPF regen cycles which are mileage based intervals unless you have a fault. Worth monitoring the DPF regen count vs your miles every so often as if it's doing it too often (AFAIK 300 miles is the usual ) it indicates something wrong like overfueling or a DPF with too much ash load. 2012 TDV8 Vogue (L322) |
25th Apr 2022 2:49pm |
Cheers guys, whilst I don't think I'm going to do oil changes every 3 months/1200 miles, I'll defo do them at 6 monthly intervals. It may be tempting to get an oil analysis test done; if those are still a thing, to see if I really need to do it more often than that.
26th Apr 2022 12:01am |
Just change 5L every 3 months and the filter every year. 2012 TDV8 Vogue (L322) |
26th Apr 2022 7:10am |
That sounds like an ideal compromise. 👍 Encourage alternative fuels, use all the petrol!
26th Apr 2022 11:13am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1366 |
Every 6 months or more frequent if more than 7,500 miles covered.
26th Apr 2022 9:06pm |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 |
Gary, got a link to the oil and filters you purchase from Opie? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
26th Apr 2022 9:17pm |
Yes, last lot I bought was the Mahle filter and Petronas correct spec oil. Cost £59.
26th Apr 2022 9:23pm |
I was always going with 6 monthly oil changes, but will look to swap some out at 3 months.
26th Apr 2022 9:39pm |
