Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
On the surface it looks to provide the same functionality as the NavPlus units but at a lower cost. Does anyone know how the installs differ? Is there any reason to avoid this unit? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
4th May 2022 7:18am |
These units take over the in built screen and send audio over the line input / aux input. A long press f a button allows you to flip between systems.
4th May 2022 7:23am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
My son had his deinstalled (if that a word) because the top few pixels went off the top of the screen as fitted. He subsequently read of the fix on the internet but it was too late then. He really is a chip off the old block. Geoff |
5th May 2022 11:02am |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 112 |
I forgot to report back the other day… I tested and, as expected, the mode button still works whilst displaying CarPlay. I don’t think this is an issue though, you’d have to be pretty ham-fisted to press it by accident I reckon. |
8th May 2022 12:50am |
Cheers for the update Full-Fat-Lance.
8th May 2022 9:47am |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 392 |
Seeking some help with my Naviplus install, if anyone could advise?
15th May 2022 12:06pm |
All original ribbons should be connected. Sounds like it will sort your issue. My guess is that you’re getting the CarPlay output as that bit is connected, but without the original connected it isn’t picking up the input to be able to pass it through.
15th May 2022 12:29pm |
Thanks , that was the issue.
15th May 2022 5:57pm |
I’m glad you got it sorted.
15th May 2022 6:41pm |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 |
Hi Tom,
17th May 2022 9:19am |
Thank you, John.
17th May 2022 10:01am |
flashheart59 Member Since: 27 Jul 2013 Location: Essex Posts: 20 |
I’ve finally got around to fitting my Naviplus after putting it off for nearly a year. It’s not been anywhere near as bad as I thought but now everything is in it won’t boot past the Range Rover start screen. Dual screen 2010. If anyone has any ideas you could make me a very happy person! |
25th May 2022 6:41pm |
Ha! Plugged the CD changer in, all works! Kudos to the OP. Great forum. |
25th May 2022 8:12pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Hi, Guys I have had the naviplus fitted by an in-car entertainment company very respected know what they are doing, They had the fitting instructions no problems.
31st May 2022 9:38am |
