Home > Maintenance & Mods (L322) > Restricted performance 4.4 tdv8
Page 2 of 4 <1234>
Discotigger
They're definitely the old hoses, so I would check those first. The split(s) can be very difficult to spot, have a look for any soot or gunk around them. Having looked at the photo, is there any gunk / soot around the RHS Rear Hose? It's difficult to tell on the photo, but it looks like that may be where the problem lies.
As mentioned, you can either get the LR upgraded hoses (quite expensive!) or you can get some silicone hose and make them up yourself.
Do a search for the long 'Restricted Performance' thread on this forum, gives you all the necessary info for the replacement hoses.
Post #632697 23rd May 2022 5:30pm
Oakesy2001uk
United Kingdom 2012 Range Rover Vogue TDV8 Alaska White
Amazing thanks - i’ll pull them off tomorrow, measure and make up
Some hoses. Hopefully thats where the issue is.
Post #632777 24th May 2022 3:37pm
Oakesy2001uk
One had a small clip on the edge of where the hose clamp is… very much hoping thats my problem! I’ll measure up for silicone ones now. Wouln’t have thought that would cause a leak where it is though…. Hopefully it has.
Post #632850 25th May 2022 10:48am
JayGee
Worth changing them but it shouldn't leak from there as it's on the outside of the clamp. 2012 TDV8 Vogue (L322)
Post #632851 25th May 2022 10:58am
Oakesy2001uk
Rubbish - that was my thinking. I’ll swap them anyway.
Anything else to check while its apart before i put it back together. New hoses coming tomorrow.
Post #632853 25th May 2022 11:08am
Discotigger
I would give the plenum and MAF sensors a good clean before putting everything back together. Maybe check the plenum for any signs of a split.
That split doesn't look like it could be the cause of the fault, where did it come off on the Plenum, i.e. front left, rear left, front right, rear right?
There's also the possibility that the jubilee clip had loosened ever so slightly due to the split, looks like something has been cutting into it.
Keep us updated. Thumbs Up
EDIT: Is there a residue of oil or soot around the split section of hose? It's hard to tell from the picture whether there's anything around where the split is or if it's just oil, etc. that's come from your hands.
Post #632854 25th May 2022 11:16am
Oakesy2001uk
Hard to say there was so much mess oily residue around/in the plenum anyway. I thought there might be some soot but minimal.
I’ll clean all the sensors tomorrow when the hoses come, put it back together and see where we are.
Post #632858 25th May 2022 11:46am
JayGee
Any black oily stuff outside the plenum means you have a leak. The throttle body to intake seal sometimes leaks as well and it's a push fit and lip seal with a retaining clip so not as secure as the intake to plenum connectors. 2012 TDV8 Vogue (L322)
Post #632860 25th May 2022 12:40pm
Oakesy2001uk
Thats probably the muckiest bit to be honest at the front, rest not to bad so that might be a favourite, the seal point in a little and is grubby - i assume its worth changing if i can find a part number. I’ll clean it all up, change the hoses for silicone hoses as well and see where we are - just waiting on hoses now.
Post #633804 6th Jun 2022 4:05pm
Oakesy2001uk
Just cleaning the donut whilst its off…
The 4 holes don't look the most round…..
One connection was a little muckier than the other 3 but not bad really. The oily horrible bit was around the egr and throttle body especially underneath which i’ve pic’d below.
Post #633805 6th Jun 2022 4:08pm
Oakesy2001uk
Cleaned it all out, 4 new hoses etc… etc…. Still going into restricted the 2nd or 3rd time you push the throttle hard on a drive. No change.
Really don’t like admitting defeat, but it Looks like i’d better let a grown up at a specialist look at it Sad
I’ll read the codes tomorrow when i get my scanner back and see if the codes are still the same.
Post #634059 8th Jun 2022 5:43pm
DrRob
CSOV check next
Also high pressure smoke test for intake leaks. Inlet manifold can split on these Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #634080 8th Jun 2022 7:28pm
Oakesy2001uk
If the csov is the changeover valve… i reached it and can opening it squeezing with my fingers… no bolt on top so its the revised one… moving eith hands doesn’t mean its working i suppose
Post #634087 8th Jun 2022 9:12pm
Oakesy2001uk
Codes are still as follows….
Intermittent - p040D-00 - egr temp sensor a curcuit high
Intermittent - p004c-77 - turbo boost control solenoid B circuit low
Intermittent - p004B-71 - turbo boost control solenoid b circuit range/performance.
Turbo b is the big one i assume - so its got to be something to do with the valve or actuator? But the valve is definitely the revised part.
Post #634144 9th Jun 2022 12:30pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I had that code it is the solenoid to the second turbo, I Changed it out and it has made a big difference to the pickup.
When I tested the solenoid by putting 12v across the terminals it worked intermittently and kept sticking? my understanding of how it works ( subject to correction ) is that when pressure builds up in the chamber it pushes up the plunger which activates the solenoid which then causes a vacuum which opens the wastegate that spins the turbo I think??
Anyway, the car was okay to drive as long as I kept the revs down if not it would go into a restricted performance which I could clear with my IID tool.
Post #634149 9th Jun 2022 1:36pm
Page 2 of 4 <1234>
