Home > Technical (L322) > Engine System Fault message |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Get it plugged in, it'll save all the guess work 2010 Disco XS TDV6, 2009 Freelander 2 GS
10th May 2011 11:18am |
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 |
Can most garages plug it in or does it need to be a main dealer/specialist ?
10th May 2011 1:08pm |
just spoke to a garage who said it could be something a simple as " FULE " ???? 2007 TDV8 Vogue SE |
10th May 2011 1:14pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
do you mean fuel "RANGEISM WILL NOT BE TOLERATED"
10th May 2011 6:47pm |
Some of the faults will be able to be picked up by EOBD kit but any of the modules beyond that will miss info.
10th May 2011 11:59pm |
Its not throwning on any lights, just a warning message.
11th May 2011 9:23am |
Really looking fr help now ! Car in at landrover and they say they cant find anything wrong but they agree it is giving a live message and is deffo down on power at low revs but only when accelerating like when over taking. It's fine from the lights and at high revs 2007 TDV8 Vogue SE |
11th May 2011 7:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
if the cars in landrover and they have done the checks and cant find anything then its going to be very difficult for someone here to find a solution.. ... - .- -.
11th May 2011 7:30pm |
You ain't seen landrover spain 2007 TDV8 Vogue SE |
11th May 2011 8:13pm |
maybe you'll have better luck reading through some of the threads here then. . ... - .- -.
11th May 2011 9:55pm |
If I had of done I wouldn't of posted this Would I . Can find anything relating to the problem as mentioned above. 2007 TDV8 Vogue SE |
12th May 2011 8:43am |
as mentioned above, you need a fault code to identify the problem otherwise its just guesswork... ... - .- -.
12th May 2011 8:58am |
As stated there is no fault code in the ecu, i had it checked again last night from an non land rover garage. there is no fault code and no light on dash just the warning message. There is a live test error saying low pressure to actuator. 2007 TDV8 Vogue SE |
12th May 2011 9:51am |
i'm confused now, so this is the answer to your problem then.. |
12th May 2011 12:48pm |
