Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
Wow, as you say, those readings are ‘interesting’ . The clutches will typically operate at hydraulic pressures around 5-10 bar (500 to 1000kPa) so the readings around 655 bar are clearly rubbish. 1.85 bar for a fill pressure (E-clutch) sounds plausible, though.
26th Apr 2020 12:37pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Not the same sensor but I too have an iid tool and it reads the map sensor as exactly that ridiculous high number but plug in my snap on and it’s normal wonder if there is a bug Current stable:
26th Apr 2020 12:42pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
I've an IID, Autologic and SDD
26th Apr 2020 1:00pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
I did my third partial change.
10th Dec 2021 6:12pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 154 |
I have done 2 partial gear box oil changes not a superflush and both times I only managed to get 4.5l back in, not too fussed as 4.5l came out, not quite sure how one is supposed to get 6 litres in. The gearbox has been working perfectly for the year I have had the car, it does work quite hard towing trailers up and down hills and motorways but we'll see in a couple of years what the longevity will be and I should have had Bodsy do the job instead.. |
10th Dec 2021 7:21pm |
Exact same numbers Red.
10th Dec 2021 8:51pm |
Has anyone experienced low fluid symptoms?
11th Dec 2021 10:10am |
11th Dec 2021 4:08pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Carried out a transmission oil & filter change today, along with changing the rubbery bits above the valve block. I didn't find any horrors in the sump, there was a bit of slurry on the magnets, but I've seen worse, the date on the filter was 2007, i've previously done three oil changes with a decent quality oil, this one was with Lifeguard 6 and 30ml of an anti-foaming agent (Shell, but with a Merc. part number).
16th Jul 2022 9:24pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1274 |
Only reset adaptations after solenoids are changed out is the general rule.... |
16th Jul 2022 10:00pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1364 |
Certainly one thing I'd do, if you didn't follow the ZF manual, is to perform the run-in procedure as ZF specify and also do an additional short distance in low range then, allow gearbox oil to cool to 40C then check the level again and top up as required. 2015 Range Rover Autobiography 4.4 SDV8 |
16th Jul 2022 10:21pm |
Cheers @dingg1 I did consider that to be the case, just thought I'd see what the collective opinion is with such an extended interval between oil & filter change (153k miles / 15 years).
17th Jul 2022 9:07am |
Phoenix, just making sure you followed the ZF service procedure for the run in part (i've done a ZHP26 before with full seal replacement)?
17th Jul 2022 10:14am |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
if you change oil 2-3 times, do you have to change sump everytime ?
28th Mar 2023 5:08pm |
