Home > Technical (L322) > Air Suspension - Gallery Pressure Won’t Reduce
dhallworth
Afternoon All Smile
As part of my LPG removal I bought a new air suspension compressor. It’s an Arnott one and comes in a complete assembly that you swap out.
I’ve fitted it and the car has built pressure and come up off it’s bump stops. I’ve now flashed the ECU to tell the ECU that it’s got an AMK type compressor fitted rather then the old Hitachi one that was there before.
I’m now getting an error message that I can’t get rid of which is putting the suspension into fault and causing it to lock out the controls.
I’ve checked everything that I can and cannot find anything that would be causing this.
When deflating the 4 corners using the IID tool the rear end of the car sinks but the front stays in the air so it’s obvious there’s a problem somewhere but I’m not sure where to look.
I’ve swapped the valve unit that has a pipe to the front, rear and reservoir over but that’s not made any difference, the symptoms and fault are exactly the same.
Has anyone got any ideas?
Thanks,
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #639494 13th Aug 2022 4:52pm
Phoenix
Sounds like the front valve block isn't venting to gallery - has the pipe been pinched? if the valve block was disconnected it should throw a DTC or two.
Post #639496 13th Aug 2022 5:06pm
dhallworth
The front valve block is right down at the bottom behind splash guards, I’ve not been near that one so am a bit confused by it.
It goes up quickly enough, just doesn’t lower.
Post #639497 13th Aug 2022 5:11pm
Phoenix
Are the height sensors OK? - as in link rods connected and nothing stopping free movement?
Post #639498 13th Aug 2022 5:30pm
Phoenix
Also, have you got the blue & black pipes in the correct positions on the reservoir block?
Post #639499 13th Aug 2022 5:43pm
dhallworth
Sorted Smile
The pressure relief valve on the bottom of the compressor needed a love tap from a 15mm spanner Laughing
They’re only £25 so I’ll order a new one I reckon.
Post #639500 13th Aug 2022 5:51pm
Phoenix
Odd how it was venting the rears and not the front though!
Post #639501 13th Aug 2022 5:58pm
dhallworth
Indeed. Very strange.
When I went back to the car, I depressurised the system with the IID tool and cracked the unions on the pipe until I found where the air stopped and then gave that a nudge. It then spat some dust out and the car depressurised no problem.
Got a feeling the desiccant in the driers on the compressor needs replacing so I’ll do that whilst it’s in bits.
Post #639522 13th Aug 2022 9:18pm
Phoenix
A few years ago i had a L319 that had dessicant in the front valve block, nowhere else, it caused all kind of issues - of course, no helpful DTC's were set... I tried cleaning the block (easy enough to open up) but the bore was scored so it was never working 100% after that. Out of warranty so the customer had to stump up for a new valve block & filter/drier, we recommended a new airline but I think the labour cost to change killed that idea!
Post #639524 13th Aug 2022 9:25pm
