Home > Technical (L322) > bluetooth
chesh
United Kingdom 2006 Range Rover Vogue Td6 Java Black
bluetooth
Hi, just got my car two days ago black 2006 vogue td6, my htc desire connected immediately and once I put the code in it was fine, but now I find that every time I go to my car my phone asks me to put the code in to connect, I would of though that it would connect automaticlly , has anyone had this issue or am I doing something wrong.
cheers Chesh Rolling Eyes
Post #63859 13th May 2011 11:58pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
My iPhone connects 99% of the time without issue, so it may be a phone problem. Try deleting the pairing fom the phone and then repairing to see if that helps, also check you have the latest software updates running on your phone.
Gone - Range Rover Supercharged 2006
Post #63871 14th May 2011 7:08am
chesh, its a known problem that if you switch of the BT on your phone after leaving the range ,when you come back you will have to pair up again...i believe a software update from the dealer solves this but they do charge for this...
Post #63882 14th May 2011 8:41am
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Re: bluetooth
My desire does the very same thing. I think it's to do with the phone and not the car. It's stays paired but every time you will have to enter the code to connect to the car. Never had this problem with my phone before the htc (blackberry bold).
cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #63949 14th May 2011 5:27pm
chesh
Well, it sounds like a phone issue, I thought it was only the i phones that had bluetooth issues, I will get intouch with HTC and see if they can throw some light on the matter and if I get it sorted I will post it. Thanks for your replies, Its a great site with lots of helpful people.
cheers Chesh
Post #63954 14th May 2011 7:07pm
allycraven
Had the same issue with my Samsung Omnia7. Software update fixed it and enabled phonebook access too. Thankfully I got the dealer to do this before parting with cash for the car so it was free....
Post #63974 14th May 2011 9:21pm
chesh
cheers , I will also give my local landrover a buzz to see if they can do an update, I will let you know, thanks for the feedback.
Cheers Chesh
Post #63985 14th May 2011 10:07pm
JustinP
I believe wiggs can do an exchange unit for less than the dealers charge to update the it.
Post #63987 14th May 2011 10:11pm
chesh
thanks for that, I was just reading about updating my analog to digital, may be I need to do it all in one go, I would like digital tv,
Cheers Chesh
Post #63988 14th May 2011 10:30pm
