Home > In Car Electronics (L322) > Issue after battery change |
Tropicvi Member Since: 09 Aug 2016 Location: Virgin Islands Posts: 12 |
My 6year old battery finally required changing. The battery shop installed a ODBii power prior to the swap out of batteries. After installation, when the car was started, the alarm sounded. Once started, it went off, only to restart the alarm on a restart or when the door opened. The display screen shows only the RR logo, windows don't work, doors won't lock, ride height won't change, and displays a message that the door is open (when it is not)
21st Oct 2022 4:14pm |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
Hi, I have 2010 L322, and you need to code the battery to the car after a swap. Is your battery the right way round? I have an App by Autel Ap200 on my phone that will code it. You can buy it on the Play Shop. |
21st Oct 2022 7:18pm |
Battery was installed correctly but it seems the battery technician shorted out the power fuse for the OBD-II connection. It is only a 5 amp fuse, probably not designed to back feed 12v into the car's system. It is typical to do that though, to retain memories in the computer components. Having replaced the fuse, the alarm stopped yelling, and most other functions resumed.
25th Oct 2022 3:31pm |
I am glad you found the cause. I believe you might have to code the radio to the car. Is the code written on your service book front page with the original purchase details? |
25th Oct 2022 4:47pm |
Hahaha ... original purchase details... ?? I am probably the fourth owner. Came off a couple of leases, went to auction, ended up on a small lot in upstate NY, before I brought it to the Caribbean almost 8 years ago. No original anything except the vehicle itself. Even the pouch of manuals was ebay purchased.
25th Oct 2022 5:04pm |
I see your location is the Virgins islands. I believe that Richard Branson lives there, and he has had Range rovers. Seems a helpful sort of chap! Seriously, Most L322's seem to have one big battery, and OE quality originals work best. Two unmatched used to work on big diesels, but modern electronics do not like them. I once had a problem with a Jagaur s-type with a seized electric handbrake, and I phoned the main Dealer Marshalls in Peterborough, who gave, on getting the vin number, a code to log into the display to rest the ECU. Worth a try? |
25th Oct 2022 6:49pm |
Yes, the US Virgin Islands. Sir Richard owns island(s) in the British Virgin Islands. Notwithstanding, I have had the opportunity to meet him and ride in one of his smaller boats with his two kids during a poker run a few years ago. I have this photo which I shot, during the trip.
25th Oct 2022 7:30pm |
I wish you well, hope you get sorted soon. |
25th Oct 2022 7:32pm |
