Home > Technical (L322) > Puddle light options. |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 308 |
Hello.
22nd Oct 2022 8:23pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1366 |
The puddle lights are Canbus monitored. When I tried Halfords 'error free' LED bulbs as my side lights in my old 3.6, it still threw an error on the dash so, they may do the same in the puddle lights.
22nd Oct 2022 9:17pm |
Thanks.
22nd Oct 2022 9:45pm |
After reading your guide I’m I right in thinking these should not be a problem once fitted?
22nd Oct 2022 9:52pm |
Generally they sell ok stuff but some of it is the same stuff available everywhere else with a massive markup on.
22nd Oct 2022 9:53pm |
All LED bulbs say interior only because technically, LED bulbs in driving lamps designed for incandescent bulbs are an MOT failure. However driving lamps are regarded as headlights, brakes, indicators, side lights, main beam and reverse obviously. They're fine to use in comfort lighting such as mirror puddles. But those bulbs linked aren't Canbus error free. 2015 Range Rover Autobiography 4.4 SDV8 |
22nd Oct 2022 9:56pm |
Thanks. Impressively comprehensive and useful lighting guide you wrote there. |
22nd Oct 2022 9:57pm |
For anyone looking I found these canbus error free 501’s.
22nd Oct 2022 10:13pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Let us know if they work OK, there are a lot of "error free" bulbs out there that don't live up to their name... Pete
23rd Oct 2022 8:20am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The 'CANBus' bit is a misnomer as well, all the lamps have to do is to draw enough current to prevent the lamp failure monitoring in the control module from signalling a defect, so theoretically with the application of Ohm's law and a soldering iron, you could make your own 'error free' LED lights, I suspect most of the failures are due to relatively high power resistors being encapsulated in small packages with little chance of airflow to dissipate the heat generated, personally, I'd mount the dummy load resistors somewhere else in the circuit with a bit of space around them. |
23rd Oct 2022 10:14am |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
I buy those, together whit full interior lights.
23rd Oct 2022 11:41am |
Decided that the LED options will be too bright for my needs, so plumped for these.
23rd Oct 2022 12:54pm |
