Home > Technical (L322) > 4.4 TDV8 2012 running issues |
Jamesonfox Member Since: 06 Sep 2022 Location: Wales Posts: 22 |
To test the injector in cylinder 6, I switched it with the one in cylinder 7. Still, I received fault code P0306, “misfire detected in cylinder 6”. How strange, I thought.
8th Oct 2022 12:53pm |
Update -
12th Oct 2022 9:17pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7646 |
Oil in the coolant and vice versa is normally caused by the oil cooler leaking….. that is, provided you have no other issues….
12th Oct 2022 9:47pm |
On the last pic, on the earlier post the small pipe is supposed to be attached to the inlet pipe, it looks to have snapped the fitting off, there is a thread on how to fix that with some threaded parts. The gunk looks like it’s been glued back on. There is nothing that can't be fixed with a hammer😜😜
12th Oct 2022 10:11pm |
mjdronfield - I really hope that’s the case and it’s not something more… catastrophic. But the oil cooler was replaced earlier last year because it was leaking oil down the back of the engine.
12th Oct 2022 11:14pm |
So far, I’ve:
23rd Oct 2022 12:55am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2784 |
Valve stem seals are only oil seals. Unfortunately I don’t see any choice but to remove the head - you have been very unlucky. 2012 TDV8 Vogue (L322) |
23rd Oct 2022 8:11am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2321 |
A failed valve stem seal can't cause low compression.
23rd Oct 2022 8:42am |
Wouldn’t a valve rocker fail safe ie closed ? 2012 TDV8 Vogue (L322) |
23rd Oct 2022 9:04am |
If the lash adjuster isn't sealing properly then the adjuster piston won't push the rocker to open the valve. Same operation as a hydraulic lifter for OHV engines.
23rd Oct 2022 9:16am |
But if the valve stays shut this won’t cause compression loss. 2012 TDV8 Vogue (L322) |
23rd Oct 2022 9:29am |
Yes it will as the inlet air is required to be compressed. If no air coming in then a partial vacuum will be created as the piston goes down. |
23rd Oct 2022 9:40am |
Makes sense. I assume these are 4 valve heads so are the rocker’s acting independently ? 2012 TDV8 Vogue (L322) |
23rd Oct 2022 10:00am |
Yes they will be operating independently as 32 are used in the engine and they're the same as used in the 2.7, 3.0 and 3.6 engines, which then casts doubt on the theory. For both to fail there would need to be a blockage in the oil supply to both, which is starting to stretch the idea. |
23rd Oct 2022 10:04am |
