Home > Off Topic - Other Cars > Stripped stud in brake disc - Helicoil or re-tap? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
As long as it is done properly a helicoil should be ok. We use helicoils for some critical stuff at sea, never had a problem with them. |
26th Oct 2022 8:19pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1366 |
Excellent. I'll whip off the disc and get it on the pillar drill. 2015 Range Rover Autobiography 4.4 SDV8 |
27th Oct 2022 5:26pm |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
If it helps, I believe the wheel bolts on Ifor Williams trailers are M14. Might help if your stuck. |
27th Oct 2022 6:34pm |
