Home > Technical (L322) > Understanding my headlights. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1368 |
On all models, the headlamps are automatic in that they come on and off depending on daylight, just like the rain sensing wipers are automatic. Both use the same sensor.
22nd Nov 2022 3:27am |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 311 |
Thanks. I guess I just have to hope the self levelling works after 13 years! What is it trying to sense to then make adjustments? Any way of testing it simply? Have to say I always dreaded coming across a Range Rover at night as more often than not I was blinded by them - now I know why! 2009 pre-facelift 3.6 TDV8. |
22nd Nov 2022 3:53am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
I don’t think my 2003 with zenon has self-levelling. I assumed it wasn’t necessary as the car has self-levelling suspension. Ron B. VK2OTC
22nd Nov 2022 5:38am |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 152 |
some early l322 was without leveling headlamps. It is described in rave. |
22nd Nov 2022 7:29am |
I can't remember exactly, but I think it adjusts when the lights come on, not constantly. If you park it facing a wall or garage then turn the lights on, you may see the light beam shift up or down slightly. 2015 Range Rover Autobiography 4.4 SDV8 |
22nd Nov 2022 9:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34965 |
those probably had halogen headlights and not hid xenons.. ... - .- -.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2800 |
The whole car is 'self levelling' . 2012 TDV8 Vogue (L322) |
22nd Nov 2022 10:58am |
I maybe a rare example of someone who uses the height adjuster on headlights quite often so hence my interest. I think I will be driving round in the hope I am not blinding people and will look out for any adjustment at night. Would love to know what the sensor is actually trying to sense in the outside world if it’s the same sensor as the rain one - can’t see how just the light / time of day can tell the headlights what height they should be. I assumed there is a set beam angle that the car tries to maintain no matter its height, but then it won’t need a sensor that reacts to the outside world?! 2009 pre-facelift 3.6 TDV8. |
22nd Nov 2022 12:10pm |
theres probably a description of this in the WM... ... - .- -.
22nd Nov 2022 12:34pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2330 |
IIRC from MY07 when the L322 was fitted with the D3/RRS Terrain Response system, headlight levelling is achieved by the air suspension levelling the whole vehicle, with the basic aim set using 2 adjustment screws on each headlight assembly. Vehicles fitted with swivelling headlights also adjust the headlights under hard acceleration and hard braking using motors within the light assemblies. |
22nd Nov 2022 12:55pm |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 27 |
I have a late 2002 td6 with Xenon and they are 100% self leveling. When you turn on the light and then the ignition you can see the beams going up and down to test the leveling mechanism. You can see it quite easily when you are parked in front of a wall. |
22nd Nov 2022 1:57pm |
Ok thanks. I have noticed the beam moving on start up so I guess my motors are working. I take it now that there is a base setting for the headlights at all times and it is adjusted based on the height of the vehicle to maintain it. So unless I start messing with the base setting via the screws on the headlights themselves the headlight throw is what it is.
22nd Nov 2022 2:06pm |
The sensor measures ambient light level and just turns the headlights on or off if you have the main switch set to auto. Nothing to do with beam alignment. 2012 TDV8 Vogue (L322) |
22nd Nov 2022 2:10pm |
Yeah, just realised that as you were typing I think! 2009 pre-facelift 3.6 TDV8. |
22nd Nov 2022 2:12pm |
