Home > Technical (L322) > P0172 - System too rich (bank 1) |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 258 |
I've had similar in the past on my BMW where I've found an air leak in the inlet tract pipework/vacuum system causing odd running, and also leaky injectors can cause similar codes
11th Jan 2023 11:31pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
An intake air leak can cause this DTC - more likely to be O2 sensor though, not the actual value, just the rate of change can be slow. Diagnostically, I've cleaned them with carburettor cleaner and reduced pressure compressed air (~50psi), this has worked but we'd always change the sensor, mainly because JLR wouldn't pay for cleaning as a diagnostic but would pay the replacement time. |
11th Jan 2023 11:38pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2986 |
Was that causing rich running?
It'll run lean until it 'realises' it's running lean, then (over)compensates - which sets the DTC. |
11th Jan 2023 11:40pm |
Cheers Phoenix.
11th Jan 2023 11:50pm |
I can't see a problem with doing that!
11th Jan 2023 11:55pm |
Good point about the plugs, I might take them out just for a look. It really is silky smooth at all times though so I doubt it’s an injector.
12th Jan 2023 12:16am |
It'd be worth swapping them over to prove it's nothing else and save unnecessary expense. If the fault does move with the sensor, given the age (and presuming they're originals) it'd be good preventative maintenance to replace both. There's no teach-in process, they're just fit & forget. |
12th Jan 2023 12:26am |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 541 |
David
12th Jan 2023 12:51am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 331 |
https://www.fullfatrr.com/forum/topic55398.html
12th Jan 2023 7:42pm |
Few more observations today:
15th Jan 2023 4:11am |
Think am going blind 😂 thought you were saying too lean.
15th Jan 2023 12:59pm |
All 8 of them are virtually identical.
15th Jan 2023 2:27pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I agree, as the fuel trim is taking out fuel to both banks I would start with looking at things common to both banks, and initially at least, discount an issue on a single injector or a single O2 sensor (and what's the chances of two or more going bad at the same time in the same way?!). You need to look at short and long term trims whilst driving as at idle will only tell you part of the story. If when driving the fuel trims are closer to 0 that would indicate the problem is only at idle and may help you with what to do next. Have you checked the fuel pressure incase there is an over pressure issue? |
15th Jan 2023 2:36pm |
