Home > In Car Electronics (L322) > Has anyone used jet automotive or automotive control |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
what about Craig at cam-tec? ... - .- -.
7th Nov 2022 1:56pm |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
Didn't cross my mind, worth a shot though, will ask the question |
7th Nov 2022 5:47pm |
Craig knows his stuff and you'll get the job done properly... ... - .- -.
7th Nov 2022 6:10pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Thanks Stan...
8th Nov 2022 1:48am |
This was a very good call Stan got the car back today and super happy knowing the job has been done properly! The car got some needed tlc at the same time too so win win
16th Nov 2022 10:52pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 201 |
Looks great, can you switch back to the car’s original system- for instance if you had the rear entertainment and wanted to use it for the kids? 2007 TDV8 Vogue SE
24th Nov 2022 10:58am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 253 |
So the website says “all factory functions retained including rear entertainment”
24th Nov 2022 1:17pm |
Yes RSE should work just fine although I haven’t tested it (never had any need to use rse to date), I’ll test it out this weekend.
24th Nov 2022 2:16pm |
For those wanting to see how the original system is still intact I popped up a very short video. I’ll do a full review at some point after I’ve lived with the system for a while and found all of the little niggles but in the meantime
28th Nov 2022 9:41pm |
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 |
Any update on this Tezza are you still impressed ?
12th Dec 2022 10:55am |
Been using it for just over a month now, I WFH a lot so it's not seen extended periods of use, maybe a couple of 90 minute trips but plenty of local runs. it's definitely not perfect but I would absolutely do it again.
13th Jan 2023 4:46pm |
your settings 'should' have an option of right hand or left hand steering wheel..change it to left and the left vertical icon band will go to the right of the screen ..more handy instead of reaching over to the left [unless you got long arms ] ... - .- -.
13th Jan 2023 5:44pm |
I am very lanky Stan but I also prefer that menu on the left.
13th Jan 2023 6:09pm |
13th Jan 2023 6:20pm |
