Home > In Car Electronics (L322) > Update on Navtool
Page 4 of 7 <1234567>
Weegie
Don’t understand about “the radio module”. You need a lead to the AUX connection. There is no connection to the radio. Everything else is in the cubbyhole at the rear. You do not need to access the front screen for installation. John
GAP iiD BT
Post #653417 13th Jan 2023 9:22am
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
I'm jumping the gun here as the kit is in transit. However, here's the diagram they shared for the connection regarding MY2010-2012:
 2012 Supercharged L322
Post #653433 13th Jan 2023 12:46pm
Weegie
My comments were in relation to 2005-2009 vehicles but, as I read what you’ve been sent, it appears to be similar. The box it all plugs into is the DVD Nav box in the rear cubbyhole not the touch screen. In that way it parallels the existing system and you can switch between them, if you wish. The phono type plugs shown are for the audio and the surround cameras, if fitted.
I think it will be clearer when you have the bits to hand. John
GAP iiD BT
Post #653439 13th Jan 2023 1:25pm
TorontoDee
Fingers crossed 2012 Supercharged L322
Post #653442 13th Jan 2023 1:50pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Can I assume that in order for the Navtool to work properly, the cars actual audio system has to be working perfectly?
Post #653889 18th Jan 2023 2:09pm
Weegie
As Version 6.0 uses the cars audio I would presume so. I’m not sure if that includes the radio. John
GAP iiD BT
Post #653923 18th Jan 2023 7:11pm
TorontoDee
First attempt at this didn't workout, so I put everything back to stock and everything is fine. I noticed afterward the dip switches on the Navtool were up instead of down too, so that could have been the issue.
It does in fact all go in under the glovebox for the 2012 model, and connects both behind the headunit (easy, 1 plug), and to the radio module above the passenger footwell (not difficult). The trick looks to be fishing a video component cable between the 2 and ensuring all the rest of the connections are tight.
So far no harm, no foul. 2012 Supercharged L322
Post #653953 18th Jan 2023 10:18pm
TorontoDee
Houston, we have liftoff!
Trickiest things were me missing that the dip switches had to be both down, and running the RCA from the new head unit harness down to the Navtool (I actually had to buy a fish tape to do it). These are all my issue.
Now to start figuring out about getting all the Android Auto settings adjusted just so...
Post #654092 20th Jan 2023 12:47am
TorontoDee
Update: everything's sorted, all's functioning as advertised.
The audio output volume issue turned out to be a missed installation step (a deadhead 3.5mm plug to the 2nd row AUX - see pics below). The lynchpin to my scenario was a plug that actuates the AUX that brings full volume to the system (between the phone, the Navtool, and the onboard stereo components). I had this "hmmm, wonder what this is for" moment when I looked at what arrived in the kit, then promptly forgot about it until chatting back and forth with support over email. Sometimes it's the little things that make all the difference.
Post #654879 27th Jan 2023 3:15pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Deadhead Plug
So to understand 100% - for wireless CarPlay you dont need to connect the Aux line? The only reason its there is for other inputs? IF that is the case you need to insert the deadhead plug to tell the system there is resistance in the aux port?
Reason I ask if that I just did the install on my MY2008 HSE - everything great but have not gotten audio hooked up (micriphone works I can be heard), but I cannot hear WAZE or SPOTFIY.
Wondering if I need that plug (which I did not see in the package).
Thanks 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #656587 14th Feb 2023 2:30pm
TorontoDee
Yes, you need the AUX. While the phone to the NAVTOOL is wireless, it outputs to the headunit & stereo components via the cabling. 2012 Supercharged L322
Post #656588 14th Feb 2023 2:32pm
RobL322
Now interested in kit for my 2004 L322
Have read this thread - albeit only once. I have apple phones and want CarPlay - to use NAV and play the music I want ( usually Digital Radio). The phone needs wireless connection. Might also be useful to have rear camera but not a deal breaker.
The vendor website is messy and their YouTube demo is only "how to use car play". Suspect many customers know this already.
Unsure what specific item to purchase. Is the 'current unit' wireless by default?
Menus lead me here https://www.navtool.com/land-rover-range-r...egory.aspx
$599 option is navtool 4.0
$359 option is navtool 3.0
Post #656917 17th Feb 2023 10:45am
Weegie
Is your L322 MY 2004 or 2005? The later 2004 were MY 2005 which has the touch screen and uses a later (2005-2009) NavTool. John
GAP iiD BT
Post #656924 17th Feb 2023 11:35am
TorontoDee
Contact them via email with your VIN. Then wait for their reply. Could even end up with an offer of a discount.
Post #656946 17th Feb 2023 3:25pm
RobL322
uncertain which MY but it does have touch screen. Guess I can email them with VIN to confirm.
This is on the list, but not in the top three yet. Smile
waiting for module to bypass steering lock issue.
waiting for better weather to attack blowing noises (exhaust manifold)
need brave pill to straighten steering wheel ( split shaft and move one single spline clockwise)
Post #657063 18th Feb 2023 2:48pm
