Home > Maintenance & Mods (L322) > 4.4 tdv8l322 Thermostat housing water outlet non availablity |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2782 |
There are severe parts shortages at the moment and according to what I was told it's going to get worse. My advice would be to see if someone can mend the existing part like I just did.
10th Feb 2023 6:31pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34953 |
google the part numbers, you might find someone that has stock.. ... - .- -.
10th Feb 2023 6:53pm |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 166 |
10th Feb 2023 7:25pm |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 155 |
11th Feb 2023 10:24am |
Where is it leaking from? 2012 TDV8 Vogue (L322) |
11th Feb 2023 10:37am |
Okay sorry my bad
11th Feb 2023 10:38am |
11th Feb 2023 10:46am |
It is the same upper part 2012 TDV8 Vogue (L322) |
11th Feb 2023 10:47am |
Thanks jaygee
11th Feb 2023 10:53am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1140 |
Have you tried doing a search for the Ford part numbers stamped on it? |
11th Feb 2023 10:55am |
Thanks all for the support, as has been said on here, the bolts fuse in the housing and it all crumbles and falls apart, mine is weeping, but its only a matter of time before it fails, its te same part on the 405 and they seem to fail more often, I am told, i got no where with Ford or trying to find the parts, so currently just monitoring the coolant and its not loosing much, but I need to source the parts. so I will keep looking. |
11th Feb 2023 7:45pm |
So yours is still on the car? 2012 TDV8 Vogue (L322) |
11th Feb 2023 8:00pm |
Yes mine is still in the car. |
12th Feb 2023 9:31am |
Where exactly is it leaking from? 2012 TDV8 Vogue (L322) |
12th Feb 2023 11:17am |
