Home > Maintenance & Mods (L322) > Hive mind question on a leak |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 721 |
Was it all cleaned up before reassembly? Did you replace the two o-rings on the oil feed pipe to the cooler at the same time? The older I get, the more I realise that people confuse wrinkles for wisdom |
14th Feb 2023 12:03am |
Jimmies Member Since: 19 Jan 2022 Location: N.Yorks Posts: 24 |
I did replace the o rings on the pipe at the back.. that was the first thing I did |
14th Feb 2023 12:39am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2705 |
The cooler can warp and crack so even after replacing the seals it can still leak. If it’s not oil leaking then the only other fluid is coolant but it should be easy to tell by look and feel. 2012 TDV8 Vogue (L322) |
14th Feb 2023 7:52am |
What torque settings did you use for tightening it all back up? The older I get, the more I realise that people confuse wrinkles for wisdom |
14th Feb 2023 10:14am |
18th Feb 2023 3:08pm |
