Home > Technical (L405) > Suspension will raise when system cooled |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
This is from an L322 owner so take caution..But...sounds like the air compressor is overheating or the air output is at a high temperature ? Couple that with the fact that it takes a long time for the car to reach normal ride height suggests that the compressor could need an overhaul or it is fighting a leak. Thus over running and heating up.Best tactic is look for a leak first, hope this helps. Does the compressor make more noise than normal ? |
25th Feb 2023 10:30pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 594 |
Hi Merchy,
25th Feb 2023 11:06pm |
That's good news about the warranty, takes the pain out of the situation, repairs can be easy, it's the diagnosis that can be a long path. |
25th Feb 2023 11:59pm |
Very true that Merchy.
26th Feb 2023 12:11am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7948 |
Just let them know you only want them to fix it if it is covered by the warranty or you could end up with a huge bill..
26th Feb 2023 12:23am |
Will do Haylands.
26th Feb 2023 12:28am |
Could I ask roughly how long it takes other members l405s to go from access height to normal? |
27th Feb 2023 4:54pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2525 |
Very quickly, if you select it manually - seems a lot faster than the L322. |
27th Feb 2023 5:46pm |
Thanks Philip, that's how I imagined it should be.
27th Feb 2023 8:16pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Nothing blocking the air going into the compressor?
27th Feb 2023 9:52pm |
No not that I can see Gremlin.
27th Feb 2023 10:29pm |
Ah, just a thought.
27th Feb 2023 11:08pm |
I could check it electronically Gremlin via diagnostics but unfortunately my SDD install is playing up.
27th Feb 2023 11:18pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
It could be a number of things including leaks at the valve blocks, sticky valves or a leak in one of the air springs. It might be worth getting the soapy water solution out and having a spray around in the absence of SDD or an IID tool. Mind you, if you have a warranty, like you say, get the dealer to do it. Kev
28th Feb 2023 8:39am |
