Home > Technical (L322) > Heater blowing cold (I doubt anyone else has had this fault) |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I have disconnected the coolant valves wiring ( As they remain open). This gives good heat flow with the Aux pump & Nothing above 1500 rpm. With the aux unplugged, the flow is minimal & low temperature, hence my next move. |
17th Jan 2023 9:28pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1366 |
I've got a 2011 TDV8 but see no reason why this same issue couldn't occur on any other engines also.
17th Jan 2023 9:29pm |
That's interesting Gary. What was the issue with the compressor & did your air con work? |
18th Jan 2023 9:53am |
The issue was the pressure release/control valve on the air con compressor.
18th Jan 2023 10:35am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1257 |
Does it instantly go cold when you go above 1500rpm, or does it fade to being cold.
18th Jan 2023 10:51am |
Gary, my AC works perfectly, so can’t see the compressor being the cause ( although I may stand corrected).😄
18th Jan 2023 11:20am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 841 |
How is it going with this 1 ?? I'm about to flush the heater matrix in my new to us D3 v8 the passenger side heat is almost non existent. Iv not read that you have tried this yet |
22nd Jan 2023 9:26pm |
Hi Dave, I've left it alone at the moment, as I have some heat & awaiting a little warmer weather .
22nd Jan 2023 10:35pm |
Well good luck with it they do try our patience |
22nd Jan 2023 10:41pm |
UPDATE - Still the same after loads of work & parts. I thnk that it's defeted me
27th Feb 2023 12:49pm |
You will be fine running no stat it will give full flow around the rad tho so not sure you will achieve what your looking for but nothing to loose. You will get full flow and leave the aux valves unplugged like you say
27th Feb 2023 9:03pm |
Only flushed with mains pressure, but had good flow. The heat at idle / low revs- speed is very good though.
27th Feb 2023 10:04pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2988 |
There’s nothing I can add to this other than to say it’s an incredibly unusual fault.
28th Feb 2023 12:44am |
David, You are correct. It's one of the bottom hoses that feed coolant around the oil coolers (Oil mixer Control valve). I've changed that & bled it.
28th Feb 2023 9:51am |
