Home > Technical (L322) > P0046-77 (2F) |
Grundey2 Member Since: 03 Jan 2023 Location: Lincolnshire Posts: 31 |
Yep, fair point.
25th Mar 2023 11:24am |
Looks like I’m making progress.
25th Mar 2023 7:26pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
If you can get an actuator, it will 'just work' in 95% of cases as the position is driven by the measured boost - the other 5% of cases needs a teach-in of the extents.
25th Mar 2023 7:37pm |
Thanks, it’s been frustrating to find but glad I’ve finally found the issue.
25th Mar 2023 7:50pm |
Just make sure you get the orientation of the actuator rod right, I've seen a remanufactured one that was assembled incorrectly and caused all kinds of problems, I've never seen a repair kit, the extents are stored in the engine control module, not the actuator, if you're replacing the mechanicals, the extents would likely be different anyway due to slight positional variations.
25th Mar 2023 8:32pm |
Many Thanks, I’ll keep you posted on progress |
25th Mar 2023 8:55pm |
Well, after many phone calls and searching the net I found the right actuator.
29th Mar 2023 8:00pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1140 |
Hi James, have you got any part numbers for the actuator please? |
29th Mar 2023 8:45pm |
There wasn’t a part number on mine, you need the part number of your turbo.
29th Mar 2023 10:51pm |
Thankyou. |
30th Mar 2023 2:20am |
