Home > Technical (L405) > L405 Transfer case - Missing Calibration? P080A-54 |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
I had this exact error, albeit on a 4.2 SC, it ended up needing a new locking rear diff actuator motor fitting / calibrating in my case, but the calibration of the transfer box actuator is available in the standard menus of an iid tool Jonathan
31st Mar 2023 4:58pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
You can perform the recalibration using the IID tool out of the box. It's not an extra paid for feature like a software update Kev
1st Apr 2023 3:52am |
There is a bug in the IID routine however. You can easily get around this by switching the engine back on as soon as it shuts off automatically during the procedure.
1st Apr 2023 3:59am |
number76 Member Since: 30 Oct 2013 Location: UK Posts: 47 |
Hi, thanks for the reply back & info too. Yes, that code can come up too for what you had as you said, with yours having a closed Diff rear locker (P080A). But my code was stored on the TCCM itself. P080A-52. Been looking into other scanners and did find that someone else did a recalibration using an Autel 808, so i might have a look down that road and see as all that money for just the RR only (IIDTool) when an Autel would do others etc. I still find it hard to believe that the TCCM "lost" the calibration!. 2014 L405 3.0 V6 Autobiography Santorini Black 49k |
1st Apr 2023 9:27am |
Thanks too for the info, very helpful. I did search a lot on the IIDTool site and read and read until my eyes hurt, but still could not get a clear answer as to what a "paid for" fast lane option was for in my case?, it said calibration was part of the unit as stock, but really focused on the Air suspension side of that, not into the TC case that i needed to know about, but if it's software update i now understand. I did speak to an indy and said he can do the re-calibration etc, but not a software update, as LR has put it's online subscription prices up from £1200 to £4k!, and he said it's just not viable anymore for him. I just want to make sure that if i buy an IID tool or an Autel 808, that i can myself do what an indi could do for me - apart from the "software update" - that as the indi's words were "a temp fix for a wear item to get around that actual problem its causing". He said there was quite a few things to do on the diagnostic side before a software update... While asking, is there a LR SSD software program you can use say on your Laptop?... 2014 L405 3.0 V6 Autobiography Santorini Black 49k |
1st Apr 2023 9:42am |
Bear in mind the iid tool can both re-calibrate the transfer case actuator & apply the latest module software update (if needed) that GAP can provide on an ad hoc basis (Fastlane service, £30 I think).
1st Apr 2023 9:58am |
Morning.
1st Apr 2023 10:27am |
Col-in-spain Member Since: 09 Mar 2023 Location: Javea Posts: 15 |
Hi,
4th Jun 2023 8:41pm |
